Help 2012 G37XS Coupe Issues
Hey guys,
Just wanted some insight on what you guys think my issues could be with my 2012 G37XS Coupe. The car has about 84,000 miles on it and has been running great but recently I have run into a couple of issues.
Thanks,
Mark
- Occasionally, when I start the car it seems like the starter / throttle isn't that strong and the car will not start. When I press the starter again then it will kick on. (I think this issue is with clearing the throttle bodies but just wanted to see what is most common)
- I recently have been smelling coolant (occasionally) coming out of the vents. It is pretty rare when I smell it but it definitely is coolant. The AC/Heat both work perfectly but I noticed that sometimes the AC will run hot at lets say 70 degrees and feel like 80 and still cool down when I lower it. I took it to a local mechanic and he said the heater core probably is failing but didn't seem too sure. How common is a heater core issue with these cars.
- Lastly, I am getting a noticeable rattling sound when I start the car and at low RPMS. The same local mechanic said it is the catalytic converter and that it seems to be deteriorating. Is it a normal thing at this mileage?
Thanks,
Mark
Check water in battery if empty or low refill with distilled water
Heater core rarely more likely radiator hose squeeze them and see if they squish or leaking
Probably motor mounts
