Slave master tube
Slave master tube
So csc tubing has the bleeder key attached to it . The bleeder key was snapped off by a mechanic. Tried to back it out with an extractor and extractor broke off inside the bleeder .. only option now is shutting the hole for the bleeder by welding it somehow and bleeding it from the top or replacing the entire slave tubing without dropping the transmission . If possible ? Infiniti dealer tech said it's possible but "infiniti doesn't like doing it without dropping it . Any thoughts ?
I don't think welding it would work. That is the only place to remove air. Plus, the high temperature of welding will turn part of the clutch fluid to ash/dust/who knows what and that debris might cause a seal failure in the CSC.
I think he best first option is to replace the slave tubing with the tranny in the car, but it will take a lot of patience.
Good luck, and please let me know how you make out.
