Battery - Airbag light - ECU
Old 01-12-2017, 01:35 PM
Tom Solimeo
Tom Solimeo's Avatar
2012 G37x sedan: Replaced the battery a few months ago. The airbag warning light has been blinking since. Tried resetting it with the starter switch method. That suceeded in making the light constanly flash a 1 7 code. Tried a handheld code reader. Would not connect. Tried a OBDII device with my Android phone and the Torque app. Connects to phone with bluetooth, but not to ECU. Appears to connect for a second and then disconnects. Help!
Old 01-12-2017, 04:43 PM
Elco
Elco's Avatar
the bluetooth adapers used winth torque can't even read the RCU error codes... not to speak about airbag codes...
try this: put the car in ACC mode (press start, without pressing the brake).
Once the airbag light turn on, turn the car off. Do NOT let wait till the airbag light start blinking
Repeat the process 7 times.
7'th time, start the engine.
The airbag light should turn off and stay off.
If the light is still blinking, there might be a problem with the airbag harness connector under one of the front seats.
Old 01-12-2017, 05:27 PM
Tom Solimeo
I'll give it a try and let you know. Thanks for taking the time.
Old 01-12-2017, 06:13 PM
Elco
Elco's Avatar
Here is a video:
On this video, he turn the ignition on/off 3 times.
I tested with 7 times because that's how it worked on my other older nissan cars and it worked just fine.
The following 2 users liked this post by Elco:
jcho01 (01-22-2017), OwenC (02-13-2017)
Old 01-12-2017, 08:16 PM
Tom Solimeo
I've tried it both ways and checked the connectors under both seats. Still a 1 7 flash.
Old 01-13-2017, 03:06 PM
Tom Solimeo
Since I can't get a code reader to connect to the ECU, would an ECU reset help?
Old 01-22-2017, 01:12 AM
jcho01
jcho01's Avatar
@Elco, Thanks! You saved me the trip to the dealer!
Old 04-14-2019, 12:10 AM
xorbitman
xorbitman's Avatar
Same problem....maybe I should try 7x's? Same question ECU reset? Not good to do a reset of the ECU BTW.
Old 04-14-2019, 12:23 AM
slartibartfast
slartibartfast's Avatar
Please explain why an ECU reset is bad.
Baadnewsburr (04-15-2019)
Old 03-06-2020, 03:04 AM
beckb
beckb's Avatar
Originally Posted by Elco
Here is a video: https://www.youtube.com/watch?v=83lPLM9MgDA
Why is this not working for me??????
