Drive without key?
Old 07-24-2016, 04:38 PM
G37xhibeet
G37xhibeet's Avatar
Drive without key?
For some reason I was under the impression that the G would not shift out of Park without the key inside the car. Today I realized that isn't the case? Or is something wrong with my car?
Old 07-24-2016, 05:54 PM
Epiphany
Epiphany's Avatar
None of the push button start cars I've ever driven lock you in park without the key. Nothing more than some annoyed beeps and a message on the dash saying the key isn't in.
Old 07-24-2016, 09:25 PM
slartibartfast
slartibartfast's Avatar
Do you mean the valet key hidden in the fob or the fob itself?
Old 07-24-2016, 10:02 PM
You only need the key to start the car. You can start it, leave it in your garage and drive infinitely, as long as you don't shut it off. Then you're screwed without it because you can't restart the car.
Old 07-25-2016, 08:51 AM
G37xhibeet
G37xhibeet's Avatar
You only need the key to start the car. You can start it, leave it in your garage and drive infinitely, as long as you don't shut it off. Then you're screwed without it because hi agent restart the car.
Yeah I realized when a family member got in and drove my car without my permission. I guess I was confused by my remote start, cause that does kill the engine if I try to drive without the key(I think)
Old 08-25-2016, 11:37 PM
SneakyBrown
SneakyBrown's Avatar
Think there's a limit of how far you can drive without the key fob then it'll kill the engine.
Old 08-25-2016, 11:50 PM
Epiphany
Epiphany's Avatar
Where have you heard that? I've never heard or seen anything about that.
Old 08-26-2016, 10:03 AM
No, there's not.
Old 08-26-2016, 01:15 PM
JSolo
Just say no!!!!!
JSolo's Avatar
It would be a huge safety issue if the car just up and died after driving x amount of time or y miles. However, if you drive off without the key, shut the car down, you will not be able to restart it.
Black Betty (08-26-2016)
Old 08-26-2016, 04:12 PM
G37xhibeet
G37xhibeet's Avatar
I would actually prefer a shut off when attempting to shift into gear, but meh
Old 09-13-2016, 08:06 AM
Fester
Fester's Avatar
I was under the impression if you put it in reverse or drive without the fob near it would kill the engine.. I always leave the car on and lock the doors and go into a store.. not anymore!!
Old 09-13-2016, 09:27 AM
G37xhibeet
G37xhibeet's Avatar
Yeah I used to do that all the time too.
Old 09-13-2016, 09:56 AM
No. Think about it for a moment. A car that randomly kills the engine WHILE DRIVING is a hundred thousand lawsuits waiting to happen. The first time someone pulls out into traffic anticipating to quickly cut across traffic, only to have the engine shut off because they left the key at home, or possibly because of a failure of a sensor to properly detect a key that's present, could cause a catastrophic accident.
The car will run and drive until you shut it off even without the key.
Old 09-13-2016, 10:21 PM
Victory
Victory's Avatar
Back when i worked as a medic our ambulances had a "security mode." You would press the button on the console and remove the key, but the truck would continue to run, but if you touched the brake pedal to shift the truck into gear without inserting the key and turning off the security button, the engine would cut out and the alarm would go off.
I can't imagine that would be a difficult modification for a car with keyless start to do if the key wasn't in range. I wonder if anyone makes such a solution. There are some situations where i would like to keep the car running during a brief stop.
Some police cars are also equipped with a hidden button to disable the shift interlock so you can't shift out of park without knowing where the secret button is located.
Thirty_Seven
10-28-2016 02:58 PM
IPL G37
09-02-2016 04:43 PM
Jonesmeister11
07-27-2016 09:58 AM
Randy Johnson
07-22-2016 11:11 AM
My_Fingers_Hurt
07-19-2016 11:56 AM
Quick Reply: Drive without key?
