Help Check engine light oil pressure code
Old 03-07-2017, 09:23 PM
saywat?
saywat?'s Avatar
so is this issue something u can see externally also or only internally ?
Old 04-15-2019, 10:54 PM
Brad Wegrzyn
Brad Wegrzyn's Avatar
Got my gasket changed
Hello I wanted to know is there any way my oil light would be setting something else off because I got the gasket thing changed I’ve had the car for a month and ever since I got the car back I put in a k and n intake but every time I would come to a stop my oil light would flash and it worries me cuz the dealership fixed the gasket for me literally 2 weeks ago plz help
Old 04-16-2019, 01:00 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Check your oil level??
Old 06-04-2019, 06:23 PM
jwhiteker
jwhiteker's Avatar
Labor time?
For those who have taken it on, how much labor time would you say it took you? I'm fairly mechanically inclined and have done some really tough timing belt changes and such. Think I could handle this?
Old 02-12-2020, 03:16 AM
VERTG37
VERTG37's Avatar
If you can get the crankshaft bolt loose it’s a piece of cake!
nothing special about it other than setting timing
Old 04-17-2022, 11:49 PM
KrisMun
KrisMun's Avatar
Is it working?
Originally Posted by Brian Londry
i got the car back on Saturday, $3100.00 later. the gasket did in fact have a 2 inch piece missing. they also replaced the chain and sliders along with 2 solinoids. they said it was not pretty in there. it is like driving a different car. much tighter and gears are much smoother. if the code does not return it was worth every single penny.
How is the car working now??? My son is having the same issue.
pkolla
10-11-2022 04:59 PM
AJLombardo
09-24-2022 09:12 AM
chenz19
11-02-2019 06:54 AM
Quick Reply: Help Check engine light oil pressure code
