Trunk Release Button Not Working. FOB & Trunk Switch (Inside) Works
#31
Update..
Got a call from Infiniti stating my car is fixed. They stated the BCM & antenna (replacement) solved the issue. Probably should have just change the antenna in the beginning.
Haven't picked up the car yet but will later this week. Just wanted to give an update & thanks to all for your input & assistance.
Fman007 (08-15-2023)
#33
Yep I just got mine back after a $6K rearend accident repair job and a floor replacement in the trunk and have the same issue. Everything works but the darn button. This will be the 3rd time I’ll have to get a rental car. First time my rear running lights didn’t work so I was driving at night with no tails. Only reason I knew was because the interior console buttons were all out as well. Thank goodness for insurance.
#34
Follow up trunk button not working.
TIA
#36
#37
Old thread same problem
Hi,
So I had my car returned from Nissan collision body shop after rear end accident.
The car came back & I am having problem w/ the Trunk Release button. Keyfob & trunk release switch (inside car) works but not when you press the button on the outside of the trunk next to the rear camera.
Took it back to Nissan body shop & they replaced the trunk release button switch & still doesn't work. They told me I can take it to Infiniti & have them diagnose it. They stated that if the problem is related to the accident then it will be covered but if not, I am responsible.
BTW... the trunk release button worked before the accident. I know because when I was rear ended, I press the trunk release & trunk opened but it would not close due to the accident . Also, I used it all the time when I go to the grocery store.
Want to know what I can check before taking it to the Infiniti dealership for diagnostic. Your input is greatly appreciated. Thanks in advance.
NOTE: I did a search & saw something about "BCM" replaced. What is BCM?
https://www.justanswer.com/nissan-in...pen-trunk.html
#38
Hello everyone , Ive managed to find put the problem with the trunk button ,
Inside the panel at the rear there is an harness with 2 lines , both was shut and touching the car panel ,
iso the 2 lines and the button started to work again
The 2 lines connected to the rear key antenna and causing the issue
hope it worked for you
Fman007
08-29-2023 10:01 AM
bartlett
02-16-2014 06:44 AM
