Help Ride height and wheel gap height
So I just installed some BC coilovers and had them adjusted. I'm having an issue and I do not know if it is suspension related or whether or not its an alignment issue. The rear ride height measurements are even equaling 25' from the floor to the fender on each side. The problem I am having is that even though the heights are the same, the wheel gaps are not. The LR wheel gap is about 1.5 inches higher. Has anyone ever had this problem or can any one help me here?? I made sure the struts and the perches were measured equally before installing them on each side. Cars never been in an accident either. Should I just get an alignment to make sure my toe and camber and everything else is in alignment?
I'm trying to wrap my head around the issue you are having.
Let's recap:
Something doesn't measure up.
Let's recap:
You measured from the ground to the apex of the fender and the values matched at 25" each side.
You then measured gap between apex of tire and fender and got a value with 1.5" deviation.
Is this correct? Would you take a few pictures, please? Basically, show the measuring tools in each location. Also, verify level ground beyond just using your eyes. e.g. bubble levelYou then measured gap between apex of tire and fender and got a value with 1.5" deviation.
Let's recap:
Let's recap:
Correct. I can't take pictures right now because I am not home but yes I know it does not make sense. Would a difference in the camber and toe from the right side possibly cause this issue? I know I need an alignment as well because my steering wheel is off centered to the right a tad.
Yea that's what I figured. Its been super frustrating. All measurements were taken on level ground in my buddies garage with a tape measure as well.
Hmmm, at 25" to the fender you shouldn't have any fender gap, that's some slammed stance, your tires should be tucked about an inch up into the fender well at 25". I'm at zero gap and I'm running 26.25" to the fender F&R.
I'm probably just missing the concept but please post some pics so we can all figure this out for you.
Is it possible one of your rear springs isn't down into the indent on the spring bucket (aka rear control arm)?
I will take a pic as soon as I can. Yea that's how the Right Rear sits. Its the LR that has the wheel gap. I will have to check to make sure the spring is in the bucket. I don't see why it wouldn't be in there. I am pretty low. I'm at about 24 3/4-7/8 " give or take in the front and 25" in the rear. Do you think an alignment would fix this issue?
G/L
ohmyg1990 (08-10-2015)
If you're that slammed and haven't had an alignment that would be the first thing on my list, it's got to be way out of spec for toe and camber if you haven't done anything to correct it. Do you have camber kits for the front & rear installed? BTW, if not, please drive very cautiously until you get it addressed.
G/L
G/L
https://www.dropbox.com/s/by700ap9zp...81020.jpg?dl=0
[URL="https://www.dropbox.com/s/sbfvg3xifm1cb5h/20150807_180620.jpg?dl=0"
Not sure if you can visit these links but here is a left side and right side comparison so you can see the LR and RR difference.
