Spongy Clutch Pedal
#46
And so I wonder why, oh why, does Nissan have such contempt for us being able to feel the clutch.
#47
Thanks vqsmile, I appreciate that. I knew I would run into some problems if i tried but it was really bugging me that I didn't at least give it a shot so I just had to try.
But yes, I did loosen the ABS module from the bottom and shifted it a bit. It provided some room for me to pull the MC out but not enough to take it all the way out. I'm not sure but maybe I'm not moving the module enough but it just seemed to not want to budge anymore and I'm afraid of forcing it and causing a kink in one of the lines somewhere so I stopped. There's just this black bracket that the module sits on top of that the MC hits and I cannot seem to get around it.
#48
Yeah, I brought the car to a shop but they were extremely busy so I eventually just worked on the car there myself. When I got stuck, they helped me out and had me remove the brake booster to get enough space to pull the master out. Bled the system with GTR fluid and everything so far has been really good. Hoping that the issue is resolved with no more problems!!
Thanks for chiming in!
#49
Thanks bro, I appreciate the advice.
How long has it been operating without any issues since the master cylinder was swapped?
Fingers crossed
#51
I was skimming through this thread. How is everything with the clutch? I had an 06Z that did the same thing. Replaced the clutch fluid and bleed it, worked for a short time and the issue came back. I did some more research and saw the the line some times weaken and will bubble out when pressure it added. I replaced it with a steel braided and that seemed to fix the issue.
#52
stevo4756
10-09-2015 01:54 AM
r0cketm0nkey
09-27-2015 01:34 PM
inspector94
09-08-2015 12:57 PM
