2010 Front Driver side and rear Passenger side locks not working
Hello,
New to the forum... Bought a mint 2010 G37x about six months ago. It did have 92K miles on it but was in great shape and had all scheduled service done at the dealer. It is a cool "rocket" car - even though my family says I drive like an old man.
I searched the site and it seems the issue is probably and door/lock actuator.
My slant on it is that both the front driver side and the rear passenger seems to died at the same time.
What I did/observed:
- Confirmed that there is no noise/clicking on either door.
- New battery in fob.
- Driver door locks/unlocks with manual key.
- Checked child safety on the rear door.
- FOB opens/locks other doors as does the inside panel button.
- Driver side Window is sluggish sometimes
Someone mentioned that the car battery might be failing although the car starts real strong.
Appreciate any help and apologies if I missed a thread on this.
Rich
Rich
Did you ever test the battery, the cables, check for corrosion/loose battery clamps/post, and how old is it?
Telcoman
Telcoman
Thanks for the quick reply.
I did not test the battery. It just happened today. The battery looks brand new and no corrosion - as does the entire engine compartment. You could eat off of it. Not sure of the age.
The idea of the battery being the culprit seemed far fetched to me - but what do I know... Is it plausible that everything else could be working fine and battery be bad? Is there a fuse(s) that could be take out just 1 - or in my case 2 locks?
Again, appreciate the help.
Rich
Rich
Will do. Raining in Louisville and I have 56 Chris Craft boat and a 67 Lincoln convertible in various states of restoration in the garage. Yes - wife hates me. Need to finish one of these before they bury me in either.
Will charge when the rain lets up and reply.
Thanks.
Rich
Thanks.
Rich
WOW!! You guys are great!!
I drove the car this AM and the locks all kicked in when I got to that certain speed. I pulled over and everything is working - Button inside, button on handle, fob.
What I did:
- Yesterday (thinking about the battery) I shut off the steering wheel automatically lift/lower when you get in/out. Also dimmed some screen setting. Not sure if any of that made a difference.
- Last night (after you all told me to check the battery) I grabbed the + and - connections and made sure they were snug. Although they all seemed tight and no corrosion, this looks to me was the fix - battery connection.
Still going to test the battery and will report back.
THANK YOU!!!!!!
Rich
What I did:
THANK YOU!!!!!!
Rich
Boomer-Bob (01-20-2017)
