Notices
Water leak under floor mats: probable cause and solution
Old 01-19-2017, 12:07 PM
gman69
gman69's Avatar
Hey everyone. My 2013 sedan just starting leaking water on the driver side floor board after it rained. I haven't had it fixed yet but plan on doing it soon. I googled all over the place and found some good info on another Infiniti forum. It's from G45driver.com and I hope it helps you out. Hell I hope it solves my problem to.
'I can't believe Infiniti hasn't fixed this issue. It's been going on since the G 35's
Here's the link.
G35-G37 Water leaks - probable cause and solution - G35Driver
Old 01-19-2017, 08:11 PM
Baby Jumpman
Baby Jumpman's Avatar
Check your grommet on the firewall if you have any type of added wiring for aftermarket accessories. Chances are the installer didn't properly seal it back up, or your sunroof drain is clogged.
Old 01-20-2017, 01:42 PM
gman69
gman69's Avatar
Thanks....
Old 01-20-2017, 02:56 PM
staskz
staskz's Avatar
agree with above, i once made a small hhole in my firewall to run some wires inside and started getting water inside, i just put a bunch of sillicone to cover that hole and problem solved
Old 01-21-2017, 09:55 AM
rpkg37xs
rpkg37xs's Avatar
I notice my leak when I switched for summer mats to my rubber winter mats I think it might be my harness so I used some tape around it and leave a rag to help collect some of the water where the brake booster is
Old 01-24-2017, 08:16 PM
Silver37
Silver37's Avatar
Agree with all the above, plus, if you've had the windshield replaced, it could need resealing - had that happen on my old Maxima a couple of years after I had it replaced and had water on the floorboard.
Old 01-25-2017, 07:20 PM
godzilla619
godzilla619's Avatar
you can try putting a fog machine in your car and seeing where the smoke comes out, probably a bad weather seal.
