Getting rid of the horn when locking the car?
Old 09-25-2016, 09:51 PM
08STLX
08STLX's Avatar
I am wondering if a dealership can do this or not but a lot of time I use the remote to lock the car instead of the button on the handle. I get the annoying horn instead of the pleasant, more legit "beep".
Can they either change the remote to the beep noise or just eliminate it all together?
Old 09-25-2016, 11:42 PM
Epiphany
Epiphany's Avatar
There's no beep, just horn or silence and flashing signal lights. Press and hold the lock and unlock button on the remote when in range of the car to switch between them.
the_wolff (09-27-2016)
Old 09-26-2016, 09:20 AM
007pipeline
007pipeline's Avatar
hmm.. good to know!! thanks
Old 09-26-2016, 09:23 AM
Vizard_87
Vizard_87's Avatar
Works on G37's too!
g37Frost (09-27-2016)
Old 09-27-2016, 05:37 PM
g37Frost
g37Frost's Avatar
Very cool trick, silencing the horn. I'm going to have to try that.
Old 09-27-2016, 06:19 PM
2011-G
2011-G's Avatar
Or you can just lock the car from inside before exiting
Also if you press the unlock button twice and then hold it down, it will roll all your windows down ( I know, I know - It's an old trick but you will be surprised how a lot of people don't know about this )
Old 09-28-2016, 09:54 AM
Elco
Elco's Avatar
Using consult 3 you can chose what type of answerback you whant on lock/unlock the car.
You can select hazard answerback ON/OFF then you can select horn, beep or no answerback on second selection menu.
I set my car to give only hazard answerback on lock/unlock and beep answerback on opening the trunk (yes you can select answerback on trunk operation too, separatly from lock/unlock)
That consult 3 cheap clone was a good investment
Old 09-29-2016, 02:26 PM
08STLX
08STLX's Avatar
how much to rent that bad boy?
Old 09-29-2016, 02:27 PM
08STLX
08STLX's Avatar
thanks all! i cant wait to get rid of that horn sound. Feels kinda cheap to me.
Old 09-29-2016, 11:06 PM
Epiphany
Epiphany's Avatar
How cheap was cheap?
Old 09-30-2016, 08:14 AM
08STLX
08STLX's Avatar
the Lord giveth, and the Lord taketh away..... when you deactivate the horn you also lose the "BEEP" on the door handle lock :/
oh well, better than that horn. my ears hated that thing lol
Old 09-30-2016, 09:15 AM
Elco
Elco's Avatar
This cheap: Nuevo Consult 3 III Professional Auto Diagnostic Tool Multi Language | eBay
For me, it worth every penny
Old 09-30-2016, 09:20 AM
Elco
Elco's Avatar
NO!
You can activate/deactivate horn and beep separately with consult 3.
Today i just reprogrammed my AV unit using consult 3 because the unit got laggy and slow to response on navi. Also, from time to time, it got stuck on back-up camera even after i was driving forward.
I performed a accessory number intialization from AV unit service menu, then reprogrammed the unit via consult 3 and it luck's like the problem is solved.
Old 09-30-2016, 09:47 AM
08STLX
08STLX's Avatar
oh nice, good to know! i may look into this one day.
Old 09-30-2016, 11:01 AM
dwb993
dwb993's Avatar
Elco---does that unit allow you to program TPMS?
Quick Reply: Getting rid of the horn when locking the car?
