Shift knobs?
Just an idea, but what about a OEM 370Z shift kn0b:
https://conceptzperformance.com/niss...z34_p_7658.php
What about vinyl wrapping the shifter surround to hide the pattern? This has been on my list for awhile. It's a slight different shade compared to the surrounding trim, some contrast might work nicely
The shift pattern is pretty mild too so I probably wouldn't worry about the trim ring. I like the brushed aluminum look so I don't know that I would wrap it.
Would it just thread onto my B&M shifter? How do you center it?
SHIFT **** UPDATE: I think I have it narrowed down to 2 options.
This is what I have now: Torque Solution Delrin teardrop- feels great and does not get hot or cold. Just looks plain and not weighted.
1st choice: Raceseng Sphereology- looks great, weighted, and height adjustable. Concerned about metal top becoming scorching hot in summer or ice cold in winter. Also, not sure how difficult it is to remove factory shift pattern from car as it would be redundant with this shift ****.
2nd choice: TWM Phantom Hybrid- looks good, weighted, height adjustable, and no worries about cold or heat. Does not look quite as good as the Raceseng Spereology and is expensive.
Let me know what you think, especially if you have one or the other. Curious about heat/cold on the Raceseng Spereology and what differences you noticed in shifting with a weighted shift ****. Also, how well does the height adjustment work? Thanks!
Even if you primarily cup the ****, instead of pistol-grip, note that the exposed SS at the top of the Raceseng Sphereology **** is recessed. You probably won't even touch it. And even if you do, the most sensitive nerve endings on the hand are at the fingertips, not the palm.
I was curious, do these things just get hot while driving, or are you talking about while the car is parked.
If it is the latter, why aren't you using a sun shade to save your dash from cracking or melting and also negating this issue?
So I have to say I am definitely leaning toward the Raceseng Sphereology after e-mailing back and forth with someone at TWM.
I sent an e-mail to TWM mentioning that I read through their website and asked for the weight of the Fastball (not listed on their site) and what the main differences were between the Phantom and the Fastball since there is a large price difference, even though they look very similar. The generic response I got back was that the Phantom was their highest quality shift **** and the most popular.
So I asked the same question again about the differences between the shift ***** and got back a rough estimate of the weight of the Fastball and links to their vague website that I was referencing and told that I should read them.
Really? So your justification for spending 3 times as much for one shift **** is that one is of a higher quality (no description of what makes it a higher quality) and that people like it? And instead of answering my question, I am told to re-read the vague website I already read? Pass
Compare that to Raceseng who actually took the time to answer my questions and even offered to make a custom CAD program to make a custom shift **** for me if I was unable to remove the factory shift pattern from my car.
I work in the customer service industry so it still amazes me how some companies totally get the importance of customer service and others are still completely clueless.
I've emailed TWM a few times in the last year, and like you I walked away unimpressed with the communication. It's like they just don't care, but are weirdly happy about it. I think they spend most of the day stoned, cashing checks and enjoying success in spite of their efforts otherwise.
Meh.
Raceseng impresses me with a unique, and innate, sense of design. I was hands-on with one of their ***** at the Annual G37 Meetup three weeks ago, and it was quite nice. The finish on that **** was amazing. And heavy, too, which is something I think you're looking for.
Meh.
Based on my own experiences, high heat is far less problematic than the effect of freezing temps.
#30
sorry, I don't check this everyday.
I have both the fastball and the Hybrid.
FASTBALL IS GARBAGE!!!!!!
absolutely crap. it's what I ordered at first. it weighs nothing and makes driving actually miserable like you're going to torque off the shift lever. I threw mine in the garbage. the plastic even felt brittle.
Hybrid is amazing. yes it's $200+. It is not difficult to keep clean AT ALL. I bought mine used. it was scratched to hell. like DEEP scratches. 2 hours and some 800grit sandpaper finished with some turtlewax a few times and I can almost shave in it (and it's white)
It's worth every penny. never changes temps, the weight makes shifting a breeze and smooth/fast. looks great. Because the shift **** is the most finger banged item in the car, I highly suggest not being cheap with it and going for quality. this is it. you won't regret it.
as for height adjustments, it threads from opening in the bottom to the very top and comes with an added 10mm (guessing on height) plunger that acts as a bump stop. probably has 2+ inches of height adjustment top to bottom. I often change my height because it changes the feel of the car IMO.
you're welcome.
you're welcome.
