Help - Radiator fan always on
As above I will start the car when cold the radiator fan runs, it will shut off from time to time but comes back on.
Anyone else have this issue?
I am not sure what to look at. I have read to check for low coolant, air in the system or a bad relay?
I had the same issue. I didn't even have to start the engine. The engine is stone cold, all I have to do is put the ignition to "ON" position, and the fans will kick in.
Turns out to be the fan control module. I bought a new one from ebay for about $65, it's pretty easy to replace.
Fan control module location on car? Thank you
Try this link, look for item 16. The module is located on the radiator shroud.Fan Control Module Image
Found it
This fixed it:
BECKARNLEY 203-0276 Cooling Fan Control Module
Took a while to get it out. Had to move away radiator overflow reservoir to get in there.
Just finished my test drive. Parked the car for a while with the engine running and no A/C, and the fans went on after about 10 minutes, then turned off a minute later. No longer running at full speed.
Very happy. That whine was annoying, especially on cold engine.
Brian Londry
20
04-17-2022 11:49 PM
ThebigJ
05-13-2016 06:13 PM
