#1666
GT-R Dead Pedal
So my 6MT dead pedal has been worn to sh*t for awhile now and I wanted to replace it. Problem is, I've had trouble finding an OEM replacement. I found the exact part number from a previous thread on this forum, but whenever I tried to order it from various Infiniti parts websites, they say out of stock and item can't be backordered.
When I went to two different local Infiniti dealerships, they said I can't order the pedal separately. I would have to order the entire floor cover for $1k+. F*ck that lol.
I looked at aftermarket pedals, but couldn't find anything I liked better than the OEM pedals. Then one day while perusing eBay, I found a used GT-R dead pedal for $50, so I said why not?
Worn OEM pedal:
OEM vs GT-R pedal:
GT-R pedal installed:
I like how the GT-R pedal is wider and the best part is it's actually made out of metal compared to the cheap plastic of the OEM pedal.
Worn OEM pedal:
OEM vs GT-R pedal:
#1667
Interior trim was scratched and dented so it definitely needed some tlc.. Previous owner must have worn rings or had hands made of sand paper. Just finished wrapping the interior with a High-Gloss Black Carbon vinyl. Love it so far. Next up: Replacing the 7AT shifter. Any recommendations?
#1669
#1671
Thanks man! I actually picked up a 24" multi-color led plug & play setup from Autozone for about 20bucks. Plugged into the 12v in the center console to avoid any hard wiring. Ran the wires behind and around the dash/floorboard. It's all plug & play you got this!
Kaykoose (09-24-2016)
#1672
i almost did not want to take it out of the packaging...
so shiney
just the tip... that is all i am asking...
yeah yeah... i needed the room under there to get the y pipe section on.. i know the jack stand is not touching...
guess i should have started earlier in the evening..
STOOPID nut... i ended up taking the whole exhaust off as one piece. i was able to get some payback and was able to remove the nut once it was out from under the car... i kicked it once or twice as well
that was my weekend... i am very happy with the sound and the butt dyno..
suspension next week i hope.. (coilovers, front and rear spc kits)
#1677
You need to get yourself a nut-splitter... Definitely makes getting those rusty exhaust nuts off MUCH easier!
I noticed this as well... That jack-stand placement looks very awkward and dangerous.
#1678
My vote's for a GTR shift ****!
