Keyfob issue
Keyfob issue
I changed out my battery on my key fob, now it only works with the valet key out of it but when put back it it acts like its dead. Anyone know what my issue could be?
Jstar
Jstar
This is strange...
I would split open the key fob and double check the battery placement and polarity. The key fob should function the same way when the mechanical key is inserted or removed.
You may want to try another new battery.
Strange indeed, the battery was new, it works fine with the key out, its not even in the same area as the battery and circuit board, its underneath in a plastic compartment below the circuit board. Makes no sense at all. I will try another battery but I tested it and it has a full 3 volts.
I know this thread is a little stale, but I have the exact same problem with one of my fobs so I thought I'd give this forum a shot. Replaced the battery again but that didn't help. Battery tests okay and works if I put in my 2nd fob that one works fine. Anyone have a suggestion?
Anyone find a fix for this?
I just replaced mine with an Energizer battery and it's been working fine.
