need part number for brake pads and rotors for 2011 g37x sedan
need some new rotors and brake pads on my 2011 g37x and the stealership just quote me $565 for each front and rear
Trying to get the part numbers so i can order them and get them installed by my local mechanic
i did search but couldn't find the info i'm loooking for
thanks
thanks
thanks
thanks
Front Rotor CENTRIC 12042080 $55.79
Rear Rotor CENTRIC 12042088 $36.79
Front Pad Set CENTRIC 10508880 $31.79
Rear Pad Set CENTRIC 10509051 $22.99
The pads come w/ shims & hardware kit
the_wolff (10-08-2015)
+1 for RockAuto. Except for the shipping into Canada. The Posi-quiets are a good pad but I found they don't perform as well as OEM. The reduce dust and noise is great but the initial bite lacks. If I could go back and re-do my order, I would have gone with the Stoptech street performance pads.
The dealership charges a lot for a brake job. I've been quoted close to $600 per axle set for a brake service and doesn't include parts. Yikes.
So I said screw it, bought the parts and did my own brake job for significantly less than what the dealership quoted me.
This^^^If you don't mind more wheel dust, the Stoptech Street Pads (once they're properly bedded in) will be a significant improvement over OEM.
These are available at Rockauto too,
Front Pads CENTRIC 30908880 $49.79
Rear Pads CENTRIC 30909050 $37.79
The Stoptechs do not require shims and do not come w/ hardware kits.
Do you need to do rotors with each set of pads? I had my 2012x at the dealership and as part of their inspection, they said my rear pads are at a "4" on a scale where "2" means replace immediately and "10" is new pads. I've only got 20k miles, would you do rotors as well, or can I get away with just pads?
On another note, they recommended rotating my tires and balancing the wheels for $79. I can rotate tires (mine are not directional), but do they need to be balanced if they're just being moved to a different axle?
my brother's friend who's a manager at my local mavis is quoting me $289 each front and back for rotors and pads (parts and labor included). I guess he's throwing the friend discount there. My question is: how good are the parts they use at mavis? should i go for it? he mentioned that he'll be using better pads and rotors (not the cheap ones that they use for any daily commuter they work on)
Check RockAuto Parts Catalog Centric Premium rotors and Posi-quiet pads will be an improvement over OEM and for a better price.
+1 on Rockauto. I'm running the PowerStop Z23 kit which was about $305 there. Installed in my driveway a few Saturdays ago & no complaints with the kit so far. After properly bedding them in they stop fantastically.
B Feelgood
09-13-2015 05:56 PM
