Just installed the Top Speed Pro 1 Y-back exhaust
Old 10-04-2015, 08:29 PM
si_driver
si_driver's Avatar
I got mine from Concept Z Performance they had it in stock and shipping was fast.
Today, I got a chance to take the car around the block. Well, unless it gets better after a few hundred miles I am no longer as impressed. The sound isn't much different than stock. Very quiet actually, I really think it isn't any louder than stock. I did not get a chance to drive the car for a longer time and/or take it on the highway. All in all, I am satisfied at least it looks better than stock, but it just isn't loud at all. Maybe after I drive it for a while and a few hundred miles it will sound better. Will see..
Again does anyone know if replacing the Y-pipe with something else get the G37 any benefits in either sound and/or performance? Maybe in the spring I could get FI High flow cats to add a little more sound and HP.
RavensMinded00, I do have a garage but it is too small to work on the car with all the stuff I have in it. The install was done Saturday morning, it did not rain in mine part of town. .
Old 10-05-2015, 12:20 AM
MILcityBoi
MILcityBoi's Avatar
It get louder bro....I have the same setup...I literally don't listen to music anymore on my way to work, all I do is put the car is sport mode and use the paddles to shift...so much fun. But to answer your question about impressed or not with the sound I know I felt the same way but now after break in period is over I am more than pleased. Hope this helps
Old 10-05-2015, 07:38 AM
si_driver
si_driver's Avatar
MILcityBoi, hopefully you are right that after the break in it will sound better a little louder.
Drove 30 miles to work this morning, the one good thing at this point, there is very little drone. Only at 1500 rpm do I hear something and it can be barely heard. I don't usually don't drive in that rpm range anyway too much.
Other other thing I noticed is that the exhaust does sound pretty nice and deep but only until about 3000rpm. After that it doesn't seems to sound too different from stock.
So hopefully MILcityBoi is right and this will change a little.
Old 10-05-2015, 12:26 PM
Drive Clean
Drive Clean's Avatar
Once you throw some HFCs in there it will get louder. I have the same setup with Berk HFCs and it's quite a bit louder than OEM
Old 10-05-2015, 01:39 PM
Received 4,940 Likes on 4,174 Posts
Did you get rasp w/ the HFCs? I'm wanting to try Fast Intentions Resonated Test pipes, but still on the fence.
Old 10-05-2015, 01:44 PM
nelledge
n00b
nelledge's Avatar
Wait... They DO make RTPs for the sedan?
Old 10-05-2015, 03:02 PM
lobuzz311
lobuzz311's Avatar
Also curious how taking out the stock cats changes tone. I really wouldn't want rasp.
The other idea I had, which I discussed with a muffler shop was creating a catback out of it. Remove the stock y pipe, remove the first section of the Top Speed with the resonators and create a new y pipe -> x pipe -> end section of the TS with the mufflers. It should free up the flow a bit via the x pipe and removes the resonators for more sound. Only problem is that my shop doesn't have a mandrel bender. Will that make a difference at these power levels? Probably not.
The cost all in was only 250, too...
Thoughts?
Old 10-05-2015, 04:12 PM
On FI's site they only list them for coupe, but Lance (1cleanG) who distributes FI pipes confirmed they indeed fit the sedan too
Old 10-11-2015, 06:42 PM
Drive Clean
I did get a little bit of rasp with the Berks, I have a video of a 1st gear pull that I took with my GoPro (Berk HFCs and TopSpeed Y pipe back exhaust) Here's the link: https://vimeo.com/141574058
I can do another video through a few more gears but the wind noise might ruin the sound quality
The following 4 users liked this post by Drive Clean:
blnewt (10-11-2015), lobuzz311 (10-12-2015), LooseGoose3 (09-21-2022), mdmill1 (10-11-2015)
Old 10-11-2015, 07:16 PM
Ricio1991
Ricio1991's Avatar
Sounds nice!
Old 10-11-2015, 08:46 PM
lobuzz311
lobuzz311's Avatar
Originally Posted by Ricio1991
Sounds nice!
Agreed.
I can't really make out the rasp in the video. Is it really subtle or is it just not really coming up in the recording?
Old 10-11-2015, 09:01 PM
Received 4,565 Likes on 3,422 Posts
I just about spit out my coffee when I realized he was backing up in the first 3/4 of that video. Too funny.
Old 10-15-2015, 06:25 PM
Mattlorentzoe
Mattlorentzoe's Avatar
highly reccomended to swap out paper like gaskets you get from top speed with some quality ones. I got the ones from z1's website and the 2.5 bolt up perfectly. it changed it from stupid loud at all times to MUCH quieter. My hfc was making it super loud but now its perfect. the sound is completely behind me now. Best $14 ive spent on my car yet
Aeroneer1 (05-24-2020)
Old 10-15-2015, 06:36 PM
  #29
Guess they've cut costs, my gaskets were decent.
Old 10-20-2015, 12:40 PM
  #30
4DOORFUN
4DOORFUN's Avatar
I think the Top Speed sounds good, but as the OP describes, the sound is mostly in the low rpms. The deep sound goes away as the revs climb, but even the high revs, it is louder than stock.
I think fitment is just ok. I had to bend the muffler hangers to get the tips centered on my bumper. The exhaust also sits directly under a suspension bolt on both sides of the exhaust. When I hit harder bumps in the road, the exhaust flies up into these bolts and clanks. The sound is metal on metal and sounds like crap. Perhaps the X cars don't have these bolts in the same location. On the S sedan, I don't see where else to route the exhaust piping.
Quick Reply: Just installed the Top Speed Pro 1 Y-back exhaust
