Wood Trim Swap
Old 09-30-2015, 12:15 AM
Upscale Speed
Upscale Speed's Avatar
Wood Trim Swap
I'm getting tired of my washi aluminum trim in my G. I want the luxurious wood trim. Has anyone e swapped there interior trim with the OEM wood trim? I have zero interest in an overlay as they are cheap looking IMO. Can anyone that switched tell me what it cost you for the OEM wood trim, where you bought it from and how hard was it to install.
Old 09-30-2015, 08:15 AM
Received 4,940 Likes on 4,174 Posts
You might try posting a WTT (Want to Trade) in the classifieds, there's been a couple that have swapped one for the other.
Old 09-30-2015, 10:07 AM
Upscale Speed
Good idea I will do that. Has anyone removed their trim and how difficult was it? Is it all clipped in or is there adhesive used too?
Old 09-30-2015, 01:44 PM
This should cover most of it
DIY: Interior Trim Removal - G35Driver
Upscale Speed (09-30-2015)
Old 09-30-2015, 02:08 PM
drewfinity
drewfinity's Avatar
Uffda. That's a lot of work.
Old 09-30-2015, 03:25 PM
RexHavoc
RexHavoc's Avatar
I'm considering swapping mine out at some point. Not certain if I would just buy new/used or trade though. I like the wood but I want CF.
Old 09-30-2015, 03:31 PM
Upscale Speed
If you get CF I'll buy your wood trim. Let me know.
Old 09-30-2015, 04:02 PM
VIVID
Pyroclastic Flow
VIVID's Avatar
You are a person of action!!!
Just saw your WTB post in the Marketplace. Good luck. I too like the wood but I'm not handy enough to attempt.
Sean
Upscale Speed (12-24-2015)
Old 09-30-2015, 04:05 PM
I removed all my trim to wrap it in brushed steel vinyl, removing the parts is pretty easy, just a bit nerve wracking as so many of those plastic panels seem like it would be real easy to break the pawls & clips, but alas, all were fine when done
Not nearly as hard or time consuming as you would think.
VIVID (09-30-2015)
Old 09-30-2015, 05:32 PM
FlyIce
FlyIce's Avatar
Sorry for my ignorance, but does "CF" means here regarding the trim?
Old 09-30-2015, 05:37 PM
hdub499
hdub499's Avatar
I'm pretty sure it means Carbon Fiber
Old 10-01-2015, 01:03 PM
RexHavoc
RexHavoc's Avatar
If I do it I'll probably be looking to work out some sort of trade with you so I can get the carbon laid over the new trim. I should really send out the window switch panels before I finish the mirror mod...
But I'll definitely let you know if I do.
Old 10-01-2015, 09:22 PM
Upscale Speed
Sweet sounds good Rex
Old 10-02-2015, 09:57 AM
botlfed98
botlfed98's Avatar
I would swap but I have an older 2007
Old 10-02-2015, 11:51 AM
Upscale Speed
Thanks, but I need the trim from a 2010-2013. I want to newer shiny wood trim. I'll look puff in my interior.
Quick Reply: Wood Trim Swap
