LED bulb recommendations...
Here's the link to the 4x bulbs:
4X Xenon White T15 T10 Samsung High Power 15W LED Backup Reverse High Stop Light | eBay
mdmill1 (08-28-2015)
Just say no!!!!!
Thanks. Placed an order too. Old age is catching up to me. Harder to see what's behind me when backing out in the dark.
Attention span is really limited these days. I remember seeing car pics in the imgur link but the ebay listing didn't register Come to think of it, most times I skip over forum posts with meaningless titles too.
Just say no!!!!!
Mine should be here by week's end. I'm a pretty tough critic of practical use of aftermarket parts. Our driveway is blocked by trees so it gets very little of the available street lighting. Will make for an easy test to see if these help or not. Will post a review after installation.
I got mine and installed them...they replaced some single Cree LEDs that were 8watts or something....upon first glance they are not as bright but def have a wider range then the single backfiring Crees...one thing I did notice was that these bad boys get Extremely Hot, so hot that one of them turned off when I left the car in reverse for more then 75/90 seconds. My Crees never did that and they were in my old M45 for about 2 years prior to my G for the last two months....I might go back to the Crees ultimately. This is just an FYI for anyone with Crees
#29
I did however, order a pair for my buddy's dodge RAM, and had a problem with one of the bulbs flickering/lighting up half way. We changed that one out and was good to go after. They don't turn off on him either. I wonder if you just have a bad bulb like my buddy did too.
#30
I installed the bulbs tonight, and they are MUCH brighter than the stock incandescents. The color is a nice, pure white - I'd say 5000k. The light the led gives off is a bit more focused than the OEM bulb. This is just due to the directionality of the "bulb", but it gives plenty of light where you need it.
I tried to get some decent pictures that showed the difference, but I didn't have much luck. I even got my DSLR and tripod out, but it just didn't properly represent what I was seeing. Oh well. You'll have to settle for these instead:
All in all, I am very satisfied. At 8.xx for 4, you really can't go wrong.
WillCo1 (09-01-2015)
