61 Month Old Battery Replace????
Old 08-14-2015, 02:21 PM
hollywhip
hollywhip's Avatar
My 2010 Sedan still has the OEM battery in it, Seems to be working fine I have topped of the cells with distilled water last year but other than that it seems fine. But with winter coming up and it's stored in a very Hot garage 5 days a week only driven onthe weekends. Do you all think I should replace it before it craps out this winter. And if so which battery would you use Die Hard, Red Top etc... ? Thanks' ahead of time.
Old 08-14-2015, 02:25 PM
xpcgamer
xpcgamer's Avatar
Good point. My brother had an 09 coupe that left him stranded 3 times due to the battery.
Old 08-14-2015, 02:38 PM
micafd3s
micafd3s's Avatar
get a vmeter and check regularly..
08 coupe here still with oe battery... northeast winters
Old 08-14-2015, 02:40 PM
Gshadow37X
Gshadow37X's Avatar
I too have a 2010, and last summer my battery died while playing the radio with the ignition turned off in a parking lot waiting for a meeting to start. I have almost never been so embarrassed in my life. I had owned the car for about three months at that point. I had it jump started, drove it to a Dealer who tested the charging system and pro-rated me a battery for $95. I couldn't quite understand the pro-rated part, but at least I didn't have to pay full price.
Old 08-14-2015, 03:34 PM
nethole
nethole's Avatar
2011 OE battery, garaged kept . . . .
Old 08-14-2015, 06:31 PM
dbeachy1
dbeachy1's Avatar
I'd replace it. I just had the battery replaced in my 2010 because it's five years old now. But it's up to you.
Old 08-14-2015, 10:14 PM
Lego_Maniac
Lego_Maniac's Avatar
My OE battery died at about 3 years.
Old 08-15-2015, 07:27 PM
chopper
chopper's Avatar
Take it to your trusted neighborhood mechanic and have them do a load test on the system. That's the only reliable way to determine the capacity of the battery. A voltmeter only gives half of the information. The load test shows how much current (amperage) the battery will supply under demand.
I just replaced the OE battery in my 2010 a few months ago. A visual inspection while checking the water level in the cells showed that several of the plates in the cells had warped. There were no performance problems apparent. I had it checked by my local mechanic and it was below 50% capacity on a load test, so it was replaced. Remember, it's usually not the cold that kills the battery, it's the summer heat. FWIW, I put in an Optima Red Top.
Old 08-15-2015, 08:24 PM
TheLocNar
TheLocNar's Avatar
Replaced my OEM battery on my 2010. Bought the car in March of that year so I am sure it was built in 2009. Had to get jumped a few times after just 10 minutes of running in Accessory mode. Replaced with an Exide 24FX from Home Depot. $100.
Old 08-16-2015, 01:31 PM
guy from norcal
guy from norcal's Avatar
2010 G Mine just crapped out on me a few months ago.
Old 08-17-2015, 12:13 AM
SS2006
SS2006's Avatar
2010 sedan here. Still with original battery, yes its died on me 2-3 times but it was nothing out of the ordinary (me leaving the lights on for a few hours), once over night. Never had problems starting up. One time though when it died (a week ago), it was near impossible to get it jumped, 3 diff friend's cars and a bunch of diff cables and it just would half-start, iwas sure it was gone for good, but then it kicked back up, and still been good since. Does extreme difficulty in jump starting a dead battery indicate poor health?
Old 08-17-2015, 04:36 AM
telcoman
telcoman's Avatar
Yes and do it today before you get stranded as others have mentioned
Old 08-17-2015, 08:19 AM
nelledge
n00b
nelledge's Avatar
What he said. Ounce of prevention and what not.
Old 08-17-2015, 08:34 AM
djdiskino
djdiskino's Avatar
I have a 2011 G37 Sedan - although I only bought it a year ago and it came CPO with a warranty to 100k - think I should just replace it or assume it's been replaced since they did the Certified Pre-owned stuff..
I also carry this in my trunk so I am not worried about getting stranded.
Amazon.com: Anker Compact Car Jump Starter and Portable Charger Power Bank with 400A Peak Current, Advanced Safety Protection and Built-In LED Flashlight: Automotive Amazon.com: Anker Compact Car Jump Starter and Portable Charger Power Bank with 400A Peak Current, Advanced Safety Protection and Built-In LED Flashlight: Automotive
Old 08-17-2015, 11:34 AM
nelledge
n00b
nelledge's Avatar
This will help if you're unsure how old your battery is.
I'm not a proponent of replacing items which are still functioning. However, a battery will only last for so long. I would say the average expectancy on OEM spec batteries for our vehicles is 3-4 years. That isn't a hard rule. YMMV. When a battery begins getting long in the tooth, it is one of the exceptions I make to purchasing a replacement part for prevention purposes.
Informative Note: A battery charger doesn't help much when you have a dead cell(s).
telcoman (08-17-2015)
Quick Reply: 61 Month Old Battery Replace????
