Touch up paint source?
I bought mine here and the color matched perfectly:
Touch Up Paint and Accessories | AutomotiveTouchup
Also, did you get the little 2 oz jug, or the touch up Pen? Does the 2 oz jug have a brush inside?
Thanks
^ I went through OC Infiniti's eBay store (when I was still living in CA, I just picked it up at the parts dept when it was ready), but it comes with 2 bottles, base and top coat. The brush is on one end of the applicator while the 'pen' is on the other end. Works well...I have the 'moonlight white' color for my G37. For my old M35, I also picked up a set in 'diamond graphite'...both colors are unique so I just went thru the dealer. Here's the link:
http://www.ebay.com/itm/Nissan-Infiniti-Genuine-Touch-Up-Paint-Moonlight-White-Paint-Code-QAA-/281750319821?hash=item4199a0b2cd&vxp=mtr
Bought mine on Amazon for my liquid platinum sedan and it was a perfect match.
That dr colorchip looked a bit intimidating. The site I looked like looked like you apply it and then wipe it with this cloth? Is it like smearing it in or something?
If you want to use a dealership touchup paint , you can go with the Lanka system. The Lanka system has another liquid formula that works for OEM touchup paints to remove excess paint . This way it can smooth out the painted area so the only thing covered by the paint is the actual exposed metal chip/nicks etc.
Here is a demo for DR COLORCHIP
I used it on my door handle where someone must have opened their door next to me when I was parked and chipped the paint off my door-handle. It was small but noticeable enough to make me fix it. It was also in an awkward & curved vertical spot so not easy to fill. I ended up using a toothpick and just dabbing very small amounts of the paint into the chip and letting it dry before reapplying. Took me a bit of time, but now you really have to look for it to find it.
I also used the brush to put some under my front bumper where I took on some curb when parking. It worked good there too.
I just bought and tried Dr. Colorchip and was very disappointed with it. I applied the process 6 times and the last time I waited 35 minutes to dry and i can still see the chips. One of the chips was l little larger than the others, but 2 of them were very tiny. I can still see the chips. On the sixth try I just put a dab on the chip like you would with an ordinary touch up paint and waited 35 minutes before I wiped it. I watched all the videos and I'm sure I did it right. When I was finished it didn't look anything like the videos.
Last edited by Creationx; 08-07-2015 at 02:15 PM. Reason: Don't want the little face.
ck1109
10-15-2015 11:06 PM
