Need help!! Diy turn as tail diode dynamics
#106
Thanks I ended up just mounting it under the tail light assembly with some sheet metal screws. Didn't even think about using the bolts already there...
#107
I heard about this as an issue, which was keeping me from pulling the trigger on the DIY module. Could anyone else with the kit advise if they are experiencing the same, or maybe Nick from DD can help shed some light?
#108
The tail as turn modules are designed so brake lighting takes precedence over the turn signal. It's safer to have the brake lighting illuminate first vs. the turn signals.
Feel free to give us a call if you would like more information about the kit: (314) 205-3033
Thanks!
Nick C.
Thanks!
Nick C.
#109
I swapped my city lights to the LED switchbacks and they all blink together in harmony.....
#110
Did you put switchbacks in the factory city light location (at the far top corner of the headlight) or the turn signal location? If you put them in place of the city lights then I'd be interested in seeing pics. I've got the V3 Tritons switchbacks in place of my turn signals and also kept the rear turn signals in the loop and replaced those with VLED LED bulbs and all flash in sync as well.
#111
#113
I just installed the T-A-T kit + resistor kit over the weekend (Thank you to DD for a great kit!). It took longer than expected but I did solder and applied heat shrink over the connections to ensure good connections. Yes, i was being a bit ****. Of course, to do this I had to remove the tail light housing but that was pretty simple. 3 nuts removed per side and it came out easier than I thought.
It turned out just as good as all the youtube videos and testimonials from the forum members, so i won't add to the collection. However, what helped me tremendously was to sketch out a crude schematic of the T-A-T and resistor with respect to the tail light wiring. I have attached it to the post and hopefully, this helps some of the sedan owners awaiting for the PNP kit from DD.
Cheers,
Jim
Cheers,
Jim
ShuuraRG (02-22-2016)
#115
But per a FB comment of one of the DD guys, they're thinking it might be here in June. So you can wait a month for something that may not materialize or you can buy the comparably dirt-cheap DIY now.
#117
Just finished the install in my 2008 sedan with the DIY + resistors kit. Took me a little longer than I would have hoped. The awkward angle for one of the tap connectors just didn't work in my favor, 2 of them pulled loose immediately after clamping them shut and I didn't have any spares. 1 quick run to the hardware store and it's all done. Looks great, thanks again DD!
#118
Every product that the guys at Diode Dynamics offer are truly top notch quality lights. I have switched out almost all my lights to their LEDs and I couldn't be happier. And for a final touch I ordered and am waiting to receive my hid headlight and foglight LEDs! Keep up the amazing work guys and thanks again for everything you've done for us all on this forum.
