amp and sub done...
Old 04-27-2015, 06:33 PM
Alexis Rivera
Alexis Rivera's Avatar
amp and sub done...
Finished my amp and sub installation, it sounds great took me a bit of time but the end result is well wortb it.. let me know wat you guys think. ..
Old 04-27-2015, 06:37 PM
Flakman
Flakman's Avatar
Looks good. That's my next major project.
Old 04-27-2015, 08:27 PM
qmantran
qmantran's Avatar
Did you use the bose amp wires for + and - or did you tap into the rear sub?
The reason why I ask is because I would like to also install a sub and amp but would like to be able to use the factory headunit to adjust the bass rather than adding and running wire for a bass ****.
I installed my sub and amp in my 08 TL and tapped into the rear sub - and + wires for power and was able to control my aftermarket sub from my factory headunit.
Old 04-28-2015, 08:13 AM
Alexis Rivera
I kept all the oem bose system intact, i believe that system sounds just great it just needed a bit of help with bass. I tap into the rear speakers not the woofer, according to the info that i gathered they have a more cleaned signal. I will be putting a bass volume *** just so that i can have better control of the bass, as you know every music is different. .
Old 04-28-2015, 08:14 AM
Alexis Rivera
Thanks flakman..
Old 04-28-2015, 11:18 AM
Flakman
Flakman's Avatar
I will likely tap into the rears as well simply from what I understand, the Bose system reduces the sub at higher volumes. So until I hear otherwise, that will likely be the route I will take.
Old 04-28-2015, 11:40 AM
JinV36
JinV36's Avatar
Does anyone know if I can replace the OEM 10" Sub in the back with a new sub / amp? And does the Bose amp power all 10 speakers ? I have every package except Tech on my g37
Rybitron
11-18-2015 03:11 PM
flyingnimbus
10-03-2015 12:12 AM
MrRiv
09-29-2015 04:59 PM
Rican149
09-21-2015 08:48 AM
m3clubracer
09-01-2015 09:36 PM
Quick Reply: amp and sub done...
