iphone6 won't pair
Old 01-04-2015, 06:40 PM
sdpike
sdpike's Avatar
iphone6 won't pair
New here, in fact first post.
My son has a 2011 and just got the iPhone6. It will not pair with the system. His iPhone5 would with no problem. Is there a software update for this? He also uses Verizon. Anyone able to pair with a different provider?
Thanks
Old 01-04-2015, 07:09 PM
connoisseurr
connoisseurr's Avatar
Is the unit a Nav or non-Nav unit?
Is the phone the same name as the old one? I had issues with that.
Also, the system only holds 5 devices so it would be good to check how many devices are paired with the radio.
Old 01-04-2015, 07:15 PM
sdpike
sdpike's Avatar
It has a nav system. The phone is the only device paired. Yes the name is the same as the old one
Old 01-04-2015, 09:13 PM
connoisseurr
Delete all stored devices on the system and then attempt to reconnect. Also delete the profile on the iPhone 6 (if there is one stored.
Old 01-05-2015, 04:58 AM
sdpike
sdpike's Avatar
Thanks will do
Old 08-22-2015, 09:45 AM
Coastie74
Coastie74's Avatar
The iPhone 6 software update released by Apple around 20 Aug 2015 solved my "iPhone 6 won't pair" problem. I have a 2009 sport coupe with navigation pkg. It worked fine with my iPhone 4, but wouldn't pair with the iPhone 6 until this week. Used the normal pairing procedure per the manual. It worked quickly (did it during a red light.)
Old 08-23-2015, 09:57 PM
e3phung
e3phung's Avatar
I had an iphone 5 paired to my 2010 g37x with navi. I got an iphone 6plus last week and it paired up perfectly, is the bluetooth not picking up the iphone 6 at all?
Old 08-24-2015, 12:55 AM
telcoman
telcoman's Avatar
Latest IOS software is 8.4.1
Do the latest update
Telcoman
Old 08-25-2015, 09:02 PM
Ipp391
Ipp391's Avatar
Weird...... My iPhone 6 connects and I can make/receive calls no problem via Bluetooth however, I cannot stream any music via Bluetooth which really sucks.. Used to be able to do it on the 5s no problem
Old 08-25-2015, 10:40 PM
e3phung
e3phung's Avatar
did you go to your music setting and activate bluetooth streaming? You have to Pair the phone for bluetooth calling and then activate the music streaming option.
Ipp391 (08-26-2015)
Old 08-26-2015, 09:47 PM
Ipp391
Ipp391's Avatar
Haha yup, that worked! Easy fix, thanks for the input
Old 09-29-2015, 02:29 PM
techisaac
techisaac's Avatar
once i have it pair how do i activate bluetooth streaming??
Old 09-30-2015, 12:48 AM
e3phung
e3phung's Avatar
I cannot recall the exact steps, just have to look around the music options or bluetooth option. Its there just hard to recall when you're not in the car.
Old 09-30-2015, 12:28 PM
tt350z
tt350z's Avatar
its in the bluetooth menu. Very bottom left box ( i think it's audio?), theres 2 options, select the audio device and a list will cone up with your phone if it's already paired. Select and add.
I'm just doing it from memory so it's kinda vague
timc00k
02-15-2017 09:15 AM
2K1 6T8
10-06-2015 07:40 PM
Msherburneg37xs
Intake and Exhaust
09-30-2015 06:39 PM
Awgd8
09-30-2015 06:22 PM
Quick Reply: iphone6 won't pair
