2009 G37X Wiper Blade
I am trying to track down the proper wiper blades for my G37X sedan. I have tried both OEM and NAPA 16" blades for the passenger side and neither work. The length is correct, but the Mitsuba wiper mounting point is slightly offset which moves the blade farther right and avoids contact with the window weather stripping on the left side.
Here is the part blade that my local Infiniti dealer gave me:
B88Y3-HS16JNW
I am almost certain this is the wrong part. Can someone point me in the right direction for the OEM part number or an aftermarket solution that works?
B88Y3-HS16JNW
I have rain x latitude on my g, and it doesn't touch or come close to the left side. I have Bosch ikons that I haven't put on yet.
i don't know why you are having a problem with the OEM part if it is the 16" blade for the sedan. that is weird.
Went to the Infiniti dealer and per the paperwork that he showed me the part number is correct, but the parts guy said that it looks like Infiniti has the wrong part number listed. I went online and it looks like the correct part number is 28890JK66A. Can someone please confirm before I place an order?
A quick follow up so that this might help someone.
The passenger wiper blade part number for G37X Sedans is incorrect in Infiniti’s system and quick reference sheet. My local Infiniti dealer showed me that the part they provided (B88Y3-HS16JNW) is what Infiniti states is the correct wiper blade replacement. Dan @ Discount Infiniti USA was able to help me as he said he recently had the same issue as I was having with another customer.
The correct OEM wiper blade replacement for 2009 G37 Sedans is a Nissan Part:
28890-1AA1A (Mitsuba)
Hope this helps!
Hope this helps!
GAWD (10-02-2014)
photocat
09-14-2015 02:32 PM
New2Infinity
09-09-2015 10:34 AM
