Front Chin Spoiler Install
#62
Pyroclastic Flow
The Clock Just Started
I ordered my OEM lip from Grubbs Infiniti Parts. They are a dealer out of Texas. Their pricing is a little better to start and Infiniti is offering a 25% off spring promo to reduce the cost. Shipping is killer though. If you find a local dealer participating in the promo you could always pick up locally.
https://grubbsinfinitiparts.com/
Promo Code: ESTORE2015
Keep in mind they don't always have these in stock so it takes some time before they ship it. I believe mine took 3 weeks.
For those numbers minded folks: $315.90 delivered. $270.00 for the lip... Which is fine with me...no sales tax ($15.00) and no three gallons of Shell's finest brew ($9.00). Plus I can sit on my copious behind while someone in blue shorts lugs the thing to my door.
#64
The ebay lip is much lower quality than the OEM one material wise. It warps unlike the OEM one which fits perfectly flush on the bumper. However, if someone is still interested I'll sell mine.
#66
Pyroclastic Flow
Yeah if I remember correctly it come with hardware....but it's an easy install...did it my self...I recommend not to install/make hole for the side brackets just incase you ever want to remove it...that way you don't ruin your stock bumper!
I used the bottom clips and the factory 3M on there and it's been on fine no problems!!!
Was that in your instructions? Did you do it? This has a pucker factor of about 5. I might want to de-mod this.
Thanks,
Sean
#67
Pyroclastic Flow
There was no hardware if i remember...
The screws are already in the bumper, remove them and the bottom of the lip lines up with the same holes, replace screws.
The lip should just have some 3M tape on it.
It also suggests a rivet through the front? i skipped on that, didn't want a hole in my bumper incase i took it off
Thanks,
Sean
#68
How did that work? My OEM lip doesn't line up with screws in the bumper. I have to drill a series of hole since the bottom lip sticks out from the bumper. The directions do say to remove those bumper screws before installation, but I suspect that is so you can get the bolts on the side which I will not be using.
Thanks,
Sean
Thanks,
Sean
#69
Thanks for the Grubbs tip. Just ordered mine. The Promo Code still works. We'll see when it gets here. Not that I'm concerned. I'll try to forget about it ... then Christmas in July!!!
#70
Pyroclastic Flow
At checkout step two, after you've selected your new chin and the color, you have to check a box accepting shipping information. Below that is a box for the promo code. Enter the code and click redeem.
Sean
Sean
#72
Pyroclastic Flow
The Chin Is In
I installed my front chin spoiler today. It took longer to cut out the templates (which I didn't use ) than the actual installation took.
Left me time to change my oil with a new oil drain plug and washer. All tight and tidy...
Anyhow,
Before:
After:
Sean
Anyhow,
Before:
After:
Sean
NSH PREDS (07-24-2015)
#73
Anyone have one of these? I really like the look although it is out of stock. right now
Infiniti G37 / Q60 Coupe TS-Style Polyurethane Front Lip
#74
Just ordered mine as well. After chatting with SheLLz a bit, I opted to go with an OEM quality lip versus the eBay version. The code is still valid, in case anyone is wondering. Wound up paying $320 shipped. I plan to respray my bumper and slap this lip on right after. Also looking to maybe upgrade to a midnight grille instead of painting my chrome one black. Painted grilles never hold up too well.
#75
Pyroclastic Flow
Looks good...however the quote from the web site has a quote that set off alarms in my head: 'WE RECOMMEND THAT ALL AFTERMARKET PARTS BE INSTALLED BY A PROFESSIONAL PREFERABLY A BODY SHOP. THE FITMENT ON AFTERMARKET PRODUCTS DO NOT FIT 100% PERFECT AND NEEDS SOME ADJUSTMENT TO MAKE IT FIT PROPERLY.'
The one I got was OEM and it stayed on with a dry fit and no fasteners. It was absolutely perfect for my car. Needless to say, I did the final install with the supplied fasteners. Not sure if what I installed is considered 'aftermarket' since it's OEM...but I did buy it after the car was manufactured...pointless observation, I'm sure.
Sean
