OBD2 OBD-II Car Auto Diagnostic Scan Tools
Old 11-25-2014, 03:30 PM
blazeplacid
blazeplacid's Avatar
Im using the ELM 327 to my Nexus 7 using Torque
Old 11-25-2014, 03:45 PM
jsampsell
jsampsell's Avatar
This is the one that I bought: Robot Check. It works great. It is WiFi, though, since the Bluetooth versions don't work with my previous iPhone 5 or my current 6+. Dash Command is free and is a great app. I use it to read the codes on friends and family's cars too. It is real time but there is a small delay. Noticeable but not frustrating. The only bad thing about this version is that when you are connected to it, you don't get internet. It's basically a tiny wireless router (with only one connection versus multiple) and your phone has no way of knowing that the router it's connected to isn't connected to the internet. So, you probably don't want to use this while commuting but it works well for diagnostics and would probably work well at the track.
It's supposed to work the same way with a laptop but I don't know of any programs that you can install on the laptop to read the device. There's got to be something out there but who knows if it's free or not. That and you still have the same problem as above. No internet while connected to it. Unless you install a cellular data antennae and pull your internet from that.
Old 11-25-2014, 03:47 PM
jsampsell
jsampsell's Avatar
Not sure why my link says "Robot Check". Ha! It's a link to Amazon.
Old 11-25-2014, 04:39 PM
G37Xtreme
G37Xtreme's Avatar
Hmmmm, maybe I'll stick with this $70 unit. They claim to have the most reports per second.
Amazon.com: ScanTool 427201 OBDLink LX Bluetooth: OBD Adapter/Diagnostic Scanner for Android & Windows: Automotive Amazon.com: ScanTool 427201 OBDLink LX Bluetooth: OBD Adapter/Diagnostic Scanner for Android & Windows: Automotive
Old 11-25-2014, 05:18 PM
jsampsell
jsampsell's Avatar
It wasn't necessary for my needs but I can see paying more for a unit that has faster communication for sure. I wonder what the difference in throughput is between Bluetooth and WiFi. More than likely, the WiFi models are using B and not N. And there could be other factors involved (like processor speed between models/version/brands). All things are not equal, that's for sure. Too many variables involved.
Old 11-26-2014, 04:19 AM
acesk8er
acesk8er's Avatar
According to Scantool.net the throughput is the same for the Bluetooth and Wi-Fi versions:
https://www.scantool.net/forum/index.php?topic=10032.0
I have the MX Bluetooth version. I opted for it over various knockoffs to get consistent performance and to avoid battery drain. It works well with my Moto X Android phone, no issue with leaving it plugged in the car.
jsampsell (11-26-2014)
Old 11-26-2014, 08:05 AM
G37Xtreme
G37Xtreme's Avatar
Is there a reason to get the MX over the LX version?
Old 11-26-2014, 01:43 PM
acesk8er
acesk8er's Avatar
Not for your Infiniti. The MX supports Ford and GM protocols that LX doesn't.
Old 11-26-2014, 04:39 PM
G37Xtreme
G37Xtreme's Avatar
I opted for the MX. Who knows what the future holds
I love Amazon Prime; I should have it Monday.
Old 11-26-2014, 10:20 PM
MalbecG37S
MalbecG37S's Avatar
I have the MX version - works very well. I keep an old Android 7" tablet around (running Torque) to talk to it...
Old 12-03-2014, 08:56 AM
G37Xtreme
G37Xtreme's Avatar
So far, I've purchased DashCommand from the Play store ($9.95). It seemed to do a better job than the OBDLink software in terms of calculations.
For example, I can't get an AF ratio in OBDLink, but I can in DashCommand. From what I can tell, OBDLink is more likely to just give me raw signal for the most part. DashCommand takes that raw signal, does some math to it, and gives me things like HP, Torque, and AF Ratio.
I do really like how customizable the dials look in OBDLink though.
Old 12-03-2014, 01:14 PM
flipmode007
flipmode007's Avatar
Do all these provide Live Data, or do I have to read the description closely? I don't want something that just reads a code, I want more from it.
At Advance Auto, the cheapest OBD II scanner that have a live feed is $99, and if I want to read ABS codes, it's $250.
Will any of these give me live info as well as ABS codes?
I am most interested in this one:
Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
Or this one:
I know it's quite a price difference, but will either of them give me both live info as well as ABS codes?
I don't think those can read the ABS sensor?
I bought the OBDII for the iPhone and It never showed anything, I went to the dealer this morning for the ABS/VDC light on and they told me that all those code were showing lol
Chris Olson
03-28-2024 09:46 AM
G's
11-05-2023 12:01 PM
Troop12
05-09-2018 02:40 PM
Thedbarz
33
02-09-2016 12:05 AM
goredcar
08-04-2015 09:03 PM
Quick Reply: OBD2 OBD-II Car Auto Diagnostic Scan Tools
