Notices
Headlights not working
Old 04-20-2014, 01:42 PM
Razorr
Razorr's Avatar
I got headlights from diode dynamics last week. The dealership installed the lights and right away one of them stopped working so I got it replaced under warranty. After installing the new bulbs they worked perfectly for a day. But since yesterday when i start the car one of the headlights won't turn on. But after turning the lights on and off a few times the lights work normally. Any idea what's wrong. These are 6000k 35 watt bulbs from diode dynamics.
Old 04-20-2014, 05:01 PM
mathnerd88
mathnerd88's Avatar
This has been discussed before.
The ballasts in this car does not like aftermarket bulbs. You should be going with Philips or Sylvania Osram HID bulbs.
Old 04-20-2014, 05:24 PM
BlueBert
BlueBert's Avatar
I saw that thread and it was for 2009+ models or something like that. I have an 08 coupe and one of my headlights just went out. I think my issue is due to the ballast as I've been having the 6k bulbs in for over 1.5 years before it went out last week.
Old 04-20-2014, 06:11 PM
Razorr
Razorr's Avatar
I read about that, but didn't see anything about the philips or osram bulbs. Are you sure they work properly. 'Cause before buying the diode dynamics light I heard many ppl say that they work well with the stock ballast.
Old 04-20-2014, 06:54 PM
'11G37S
A 1/4 mile @ a time
'11G37S's Avatar
I tried diode dynamics 6k bulbs and they did not work. I then went with Osram and haven't had any issues since.
Old 04-21-2014, 02:18 AM
Drive Clean
Drive Clean's Avatar
Hmm, for what its worth, I've been using the diode dynamics 6k bulbs for around a year on my 2012 sedan without any problems.
Old 04-21-2014, 03:32 AM
socialconflicts
socialconflicts's Avatar
i second this as well. mine have been flawless for over a year now. i went from a 2008 g coupe to a 2010 sedan. both have been good.
Old 04-21-2014, 07:26 AM
mathnerd88
mathnerd88's Avatar
The Matsushi-ta ballasts in our cars are known to be picky with what type of bulb it works with.
That being said, you have a much better chance of them working if you use Philips or Osram bulbs. This has been posted on the HIDPlanet forums as well as theretrofitsource.com
While aftermarket bulbs may work with the car, it may also not, depending on how the bulbs were made. They don't adhere to as much strict tolerances as the OEM bulb companies.
I will post again what theretrofitsource (legitimate HID store) says about these ballasts:
"The Matsushi-ta ballasts are best used with Philips or Osram bulbs, sometimes have trouble igniting aftermarket lamps."
If you find out that your bulbs aren't working, change them to OEM. They should work.
telcoman (04-21-2014)
Old 04-25-2014, 02:07 PM
TenshiroG37
TenshiroG37's Avatar
There's no other options that will work beside the Philips or Sylvania Osram HID bulbs???
Are there anyone else using something else that works and stay on???
Old 04-25-2014, 04:53 PM
Diode Dynamics
Diode Dynamics's Avatar
We removed the 2012+ HID replacement bulbs from the site, as we noticed flicking with some of the 2012+ models.
Nick C.
Old 04-25-2014, 10:07 PM
JohnnyD
JohnnyD's Avatar
Morimoto 3Five 6000k bulbs here, less than a year since install with no problems. They work first time, everytime. Also about 1/4 the cost of Phillips or Osram bulbs.
j50ny
07-21-2017 10:46 AM
OneSickBlackG
01-06-2016 08:49 AM
tomro99
11-17-2015 02:08 AM
Upscale Speed
10-09-2015 01:42 PM
uzbekuz
09-08-2015 11:45 AM
Quick Reply: Headlights not working
