Wrapping My G37x Matte Silver M21
#92
so the idea.. lets say if i end up getting matte metallic blue. when the vinyl is being applied one would heat it up + stretch it (how much of a stretch?) and then lay it down?
#93
@Dj1ofDet, i did not take the tail lights out, i removed the roof striping, door handles and antenna .
@socialconflicts, make sure you are in warm temperatures, too cold and the wrap will be extremely hard to work with and will tear very easily, lay the wrap, stretch it out as much as you can and lay flat, then start heating and squeegying,
once finished wrapping, go over the whole wrap with the heat gun again to activate the glue and create a good bond.
#94
I am starting my own full wrap project this weekend and 1 of my questions is can I use a heat gun on low setting directly on taillights? I have a design in mind but I am concerned it would crack the plastic housing...
#96
Here is another stupid question: I am going to be using Vvivid brand vinyl. It says "dry application", bur using Primer and Sealer is recommended. However, would I still benefit from using RapidPrep and RapidTac? If so, I'd order those today. It basically says that RapidPrep degreases the surface and removes wax, etc. And RapidTac allows for wet install and easier sliding of vinyl on the surface. However, dry installed is recommended. What are your thoughts on that?
photocat
09-14-2015 02:32 PM
