Notices
Beginning Custom Headlights
Old 12-25-2013, 07:59 AM
  #61
GoFightNguyen
Because Racecar
GoFightNguyen's Avatar
Originally Posted by ninjitsui1
Nice bro! What color are the shrouds?
On my 2012 g37 the headlight shrouds come in black chrome already, so there was no need to paint anything.
Old 12-25-2013, 12:14 PM
  #62
connoisseurr
connoisseurr's Avatar
Looks great! The color combo in there is just perfect. Can't wait to see them all wired up correctly.
GoFightNguyen (12-25-2013)
Old 12-25-2013, 02:49 PM
  #63
Received 4,940 Likes on 4,174 Posts
That's going to be a killer combo Anthony, looking forward to the end result.
Old 12-25-2013, 02:59 PM
  #64
GoFightNguyen
Because Racecar
I'm gonna do a headlight restore after these get wired up. I'll put up a DIY for a tsx-r lens swap, and for wiring the angel eyes.
ninjitsui1 (12-27-2013)
Old 12-25-2013, 03:02 PM
  #65
That would be great, those DIYs are surely needed
Old 12-25-2013, 03:39 PM
  #66
connoisseurr
I'll be working on a thorough DIY for the sedans as I haven't found a true detailed one. I plan to include the disassembly of the housings, lens swap, painting, LED installation and testing.
The following 2 users liked this post by connoisseurr:
blnewt (12-25-2013), ninjitsui1 (12-27-2013)
Old 01-01-2014, 04:24 PM
  #67
GoFightNguyen
Because Racecar
Got my inverter board and finally had some time to wire up and test one of my lights. Are you ready?
Old 01-01-2014, 08:42 PM
  #68
GoFightNguyen
Because Racecar
This turned out better than I could have possibly imagined! Thanks for all the help guys, i have exactly what I wanted, quad angel eyes on a DRL harness, for less than 180 would charge all in!
Old 01-01-2014, 10:15 PM
  #69
Looking nice Anthony, how long did that take (once the parts finally arrived)?
Old 01-01-2014, 10:31 PM
  #70
GoFightNguyen
Because Racecar
Not that long. My harness worked perfectly, and I eventually found the right fuse to tap 12v acc from. I spent the lions share of the time troubleshooting connections. I used butt splices for a lot of connections and a few were loose. Probably all in, it took me 14 hours spread out over 3 days to remove, open, mod, and reinstall the headlights and relay harness.
Old 01-01-2014, 10:34 PM
  #71
That's not bad, BTW you swapped to TSX-R lenses right? How do you like the new cutoff and overall output?
Old 01-01-2014, 10:41 PM
  #72
GoFightNguyen
Because Racecar
I did the swap, there's some good color flicker. When I get a chance, I need to aim them more accurately. As is, I get a big "step down" in the cutoff where the drivers side headlight cutoff dips to around 6 inches lower than the passenger cutoff at 25 feet.
I like the new output, it adds a little more blue tinge. The swap was odd, since I had to use a brass punch to pry off the lock ring holding the lens on.
Old 01-01-2014, 10:53 PM
  #73
I've heard the coupe 2.5" lens is secured differently than the sedan, interested to see the way it's secured. How much spacing did you use for the lens?
Old 01-01-2014, 11:08 PM
  #74
GoFightNguyen
Because Racecar
There's no screws to undo to remove the lens. The lens is seated in a frame and there is an aluminum ring that fits over it. The ring is then bent into divots in the frame to hold it in place. Pretty shoddy way to hold it on.
I didn't see any spacers in the OEM setup, so I just dropped the lens in with no spacers. I think that was the right decision.
Old 01-01-2014, 11:22 PM
  #75
I didn't use much spacing w/ mine either, did yours come w/ a wire ring spacer or cardboard spacers? I didn't like the way the lens was secured w/ that wire ring so I just used a bit thicker cardboard to sharpen the cutoff a bit.
So your lens isn't even securely screwed down like this~
Quick Reply: Beginning Custom Headlights
