Notices
Beginning Custom Headlights
Old 12-20-2013, 08:14 PM
  #46
connoisseurr
connoisseurr's Avatar
Looks great! Can't wait to see the installed pictures.
Old 12-20-2013, 08:40 PM
  #47
GoFightNguyen
Because Racecar
GoFightNguyen's Avatar
Thanks, it took several hours for the first one, I had to nail down exactly what I was gonna do, the second headlight took less than an hour open to close. They're both wired to connectors and ready to install and attach to my DRL harness. I'll tackle that tomorrow morning. Fingers crossed they light up first try.
Old 12-20-2013, 08:41 PM
  #48
GoFightNguyen
Because Racecar
Question: I've got a fuse tap, what slot on the fuse box should I tap to get an ignition/acc +12v? This will connect to the relay, not directly to the lights.
Old 12-20-2013, 09:44 PM
  #49
monytx
monytx's Avatar
I'd say to ignition man. Seems logical to me. Looks so good.
Old 12-20-2013, 09:51 PM
  #50
GoFightNguyen
Because Racecar
Big shoutout to Mo for coming by and lending both hands to headlight removal, modification, and wiring.
Old 12-20-2013, 10:19 PM
  #51
monytx
monytx's Avatar
No problem dude. Although all I did was hold the flashlight. Lol. It was a lot of fun. I'll send you the pics tomorrow.. or do you want em now?
Old 12-20-2013, 11:13 PM
  #52
JPSBLACKG37
JPSBLACKG37's Avatar
Yes...... I think I would know this. I've done many many many headlight jobs before and this has always been my effective way of removing the chrome paint and prepping the housings. I'm not removing ALL the chrome with the 80 grit, I'm simply roughing the surface of it. The 150 will come through and do the job nicely then. I'm not trying to start a pissing war with you here, just elaborating on my my techniques.
I may not paint cars for a living, but I have a common knowledge of painting techniques and procedures. I also have the knowledge of painting a car myself and wouldn't use this method on the exterior of a vehicle. With that being said, I really don't care to take your advice, but thanks for the input.
You're just wasting your time is what I'm saying.... You don't need to sand anything with 80 grit.... OR 150 grit.... The surfaces are perfectly smooth as is.....spray adhesion promoter directly on the parts and paint.
Old 12-21-2013, 12:02 AM
  #53
Received 4,940 Likes on 4,174 Posts
My 09 might be different but here's the slot I used, just put a multimeter up to check for power w/ ignition button depressed. This slot turns on when the ignition button is pushed w/ or w/out the brake pedal pushed so it's powered when the radio is on, not just when the engine is running. This wire goes to a switched relay then to the lights. BTW, nice job you've done thus far, you got a lot done in a short time
Old 12-21-2013, 11:25 AM
  #54
connoisseurr
This exactly. I went through and found a couple open slots on the sedan. Otherwise, you can just you a mini add-a-fuse
Attached Thumbnails Beginning Custom Headlights-image-423211541.jpg   Beginning Custom Headlights-image-1189935821.jpg   Beginning Custom Headlights-image-1093941790.jpg
Old 12-21-2013, 02:00 PM
  #55
GoFightNguyen
Because Racecar
Hit a roadblock guys, the rings I ordered are CCFL, I didn't know they require an inverter board. They wont work on DC power. I'll have to overnight some inverter boards from Diode Dynamics and retry the install. However, the rings are installed and the harness is ready.
Old 12-21-2013, 04:37 PM
  #56
Damn, tough time to have delays, especially when you'll probably be tied up w/ family time for the holiday week, good luck.
Old 12-25-2013, 12:01 AM
  #57
GoFightNguyen
Because Racecar
Some pics of the rings installed.
Old 12-25-2013, 12:26 AM
  #58
monytx
monytx's Avatar
I think I want now. The blue looks pretty hot back there.
Old 12-25-2013, 12:30 AM
  #59
GoFightNguyen
Because Racecar
I can't wait until I wire them up and get them to actually *work*
Old 12-25-2013, 02:18 AM
  #60
ninjitsui1
ninjitsui1's Avatar
Nice bro! What color are the shrouds?
Quick Reply: Beginning Custom Headlights
