Sedan Chat Thread
#6273
Yep. Fast Intentions, 2.5" pipes with 18" resonators. I ordered it the day after Xmas.
#6276
Maybe because you're nearly murdered, it will look fantastic. But I also think this spoiler works better design-wise if the flat, OEM duckbill spoiler is on the car. Although that's probably over-thinking things. I do that a lot. Heck, we all do that a lot.
twin_snails (03-27-2015)
#6278
https://www.myg37.com/forums/g37-sed...-extreme3.html
#6280
wow thank you sir for the info and links. While a 2 peice rotor would be ideal.....unfortuantely the pair for $920 is a bit out of my price range at the moment. Still unsure of what I'll be pulling the trigger on....was intitally looking at these
F R Premium Drill Slot Brake Rotors Posi Quiet Ceramic Pads BPK47829 | eBay
and then after the debate are now looking at these
F R Brakenetic Premium Slotted Brake Rotors Posi Quiet Ceramic Pads BPK72487 | eBay
No problem Sir! Yeah the price is steep and I guess I was fed up with the stock units. And I will admit, it is a little crazy to spend close to $2k on rotors/pads and stainless lines.
I'm with you on anti drilled and anti made in China. In my reading last night, I also learned that many of the cheaper companies (made in China) start with blanks, then drill them and as a byproduct, they're not balanced.
In for pics once you get the spoiler installed Lego.
#6282
I know John has mentioned really liking the 2016 Jaguar F-Type sport and in that spirit, just this week I realized how sweet looking the current BMW M6 Gran Coupe is. To me, the design strikes an awesome balance between muscular and elegant at the same time. Discuss.
#6283
Got a question for you guys.
Currently running a 15mm spacer in the rear, with a 45mm stud. (stocks are 30mm). I am thinking about swapping to a 17mm spacer. Think I would be alright adding an extra 2mm (i guess in this case subtracting) on the 45mm studs? I know people have (unsafely) run a 5mm spacer on a 30mm stock stud, but I'm not willing do that. haha.
#6284
And the rear single piston sliding caliper is lame.
#6285
