Sedan Chat Thread
Old 01-28-2015, 02:56 PM
  #5716
Lego_Maniac
Lego_Maniac's Avatar
Perhaps some recon is in order. We'll see how this week shapes up.
Let me know. Probably going to schedule the clutch bleed for next weekend.
Old 01-28-2015, 05:11 PM
  #5717
doublea88
doublea88's Avatar
Anyone have any tips for easy tint removal ? I got pulled over today for my tints (%35 front and %20 rear). I'm done with being harassed for tints and will just remove my front window tints. Read that people use a fabric steamer or a blow dryer, and wanted to know if anyone tried that before. Thanks.
Old 01-28-2015, 05:13 PM
  #5718
ttv36
Race, repair, repeat.
ttv36's Avatar
^ I think I got charged around $20 to remove my front window tint when I was making them darker. Perhaps going to a tint shop may be something you can consider as well.
Old 01-28-2015, 05:19 PM
  #5719
ChinkyChoy
ChinkyChoy's Avatar
heat gun works took mine off before I got it redone to avoid an extra 20 bucks
Old 01-28-2015, 05:29 PM
  #5720
doublea88
doublea88's Avatar
I went to the shop that installed my tints and they said it would Cost $75 to remove the tint. Figured i'd just do it myself and save the $$ for something so simple that will only take 5-15 minutes.
Old 01-28-2015, 05:39 PM
  #5721
ttv36
ttv36's Avatar
Wow $75, yeah I would definitely be trying to pull them off myself too! Sounds like heat gun would work according to CC.
Old 01-29-2015, 09:31 AM
  #5722
pledes23
pledes23's Avatar
A fabric steamer would be best if you have one, because the steam will help remove the tint but will also loosen up the glue making it easier to gently scrape it off. Also if you have a spray bottle with warm water and dish soap (I used Dawn) and a blade carefully scrape the excess glue from your windows. Then I just used Wiindex and newspaper to clean the windows for streak free shine (yes I might get ridiculed by it, but its an old school method to cleaning windows which I prefer) You can get a small portable steamer from kmart for about $20.
Old 01-30-2015, 01:33 PM
  #5723
doublea88
doublea88's Avatar
Thanks for tip Pedro, I ordered a steamer and it will be here tomorrow and can't wait to get those tints off! In other news, I received my New Black Nickel R2C Intake. Was trying to start putting it together before i head out to the car and noticed that the mid pipe won't be sitting flush against the heat shield from the top bolt due to the rubber around that area. Am i supposed to cut it so that the mid pipe can sit flush against the heat shield?
Attached Thumbnails Sedan Chat Thread-img_1646.jpg   Sedan Chat Thread-img_1647.jpg   Sedan Chat Thread-img_1648.jpg   Sedan Chat Thread-img_1655.jpg   Sedan Chat Thread-img_1656.jpg
Old 01-30-2015, 01:54 PM
  #5724
Received 4,574 Likes on 3,425 Posts
I don't recall that being a problem. Perhaps they're using larger rubber edge-molding these days? I see you opted for the new Black pop-chargers.
There were a number of issues I had with the R2C kit. Ignore what you can't fix, and fix what you can (like this issue here you're talking about).
Here's a follow-up thread to my install from 1.5 years ago. If you've not seen it before, maybe it will help, maybe it wont:
https://www.myg37.com/forums/g37-sed...s-learned.html
doublea88 (01-30-2015)
Old 01-30-2015, 02:25 PM
  #5725
doublea88
doublea88's Avatar
Yowza, that's quite the review there, really informative and precise to detail. I couldn't tell if you had the same issue or maybe they just larger rubber molding (don't know why they would). I don't mind making the adjustments to it but it would have been much easier if it was made to spec for bolt on installation. I'll be referencing your link as i go with the installation, you sure went above and beyond which is exactly what you should be doing for these mods.
Old 01-30-2015, 02:29 PM
  #5726
Welp... that made my day.
Old 01-30-2015, 03:17 PM
  #5727
G37Xtreme
G37Xtreme's Avatar
Can you go UNDER that trim with the lip of the pipe?
Old 01-30-2015, 03:44 PM
  #5728
doublea88
doublea88's Avatar
I tried that at first but it looked like it was glued on but after not finding any answers, i was about ready to cut that rubber lining to fit but ended up prying it up and moved it up a bit and it now fits perfectly. The rubber was simply sitting too low.
Old 01-30-2015, 06:11 PM
  #5729
ChinkyChoy
ChinkyChoy's Avatar
some goodies came in
Old 01-30-2015, 07:37 PM
  #5730
Hey, where's your driver side relay box?
Looking good. You should dip into that FSTB thread and comment on your GT-Spec bar.
Quick Reply: Sedan Chat Thread
