Sedan Chat Thread
#4996
Here: http://www.nicoclub.com/FSM/G37/Sedan/2011/EM.pdf
#4997
Thanks for the link, that will definitely come in handy. It sure is complicated with how many parts and hoses you have to remove to replace something so simple. Yet the torque procedure sure is complicated, hence if you don't want any oil leaking anywhere. Will save that link for when I find the part, appreciate the help.
#4998
So I managed to pick up some brand new FI 2.5" RHFC made for the coupe but it will fit the sedan as well.
should I tackle this install myself or just bring it to a shop only problem is I m not familiar with most shops around here. and I m worried I wont be able to break the bolts loose from it being rusted when I did my exhaust it was a nightmare.
But I m def gonna try to get a video before install and after install.
The RHFC will be paired with an ARK CBE
#4999
#5000
#5001
#5003
Thanks for all the feed back I ll take a look at the bolts and try to figure out if I ll be able to do it. I don't want to get a couple bolts off then get stuck half way through.
If its anything like my catback system I ll be taking it to a shop. I do have access to most of the tools including air tools because the air force bases have some really nice auto hobby shops we can rent stalls at
#5004
If you are working on base, make sure you have time to knock this out, it became an ALL day project for me. I don't know about your hobby shop on base but ours would close kinda early sometimes and you'd get rushed out of there.
