Sedan Chat Thread
#4111
well I certainly have questions on any tips installing V3 Triton LEDs/switchbacks as the system is completely different from regular switchbacks out there, which I still have on the car, but after getting my headlights done with dual evil iron man leds, I had OnEighty bend one of the pins on the bulbs so the white doesn't stay on, only amber turn signal works, but the light output isn't good enough anymore considering the evil iron man leds are putting so much light that the turn signal is hardly noticeable anymore, therefore I got the V3 Tritons as they are the brightest, with the best light output on the market. Thanks though.
The ones I installed claim the White is 650lm and Amber is 350lm vs the Triton White at 600lm and Amber at 430lm.
Long as it all macthes (headlights, fogs, turns) imo then your good, best of luck with the install
#4112
I gotcha, well I dont know much about the Triton LED's but my switchbacks I installed have a very similar lumen output and I must say they are extremely bright! Very happy with the outcome
Here is a picture of the Evil iron man lights for reference... now imagine the turn signal there.. barely noticeable lol
I think I'll snap few pictures with the old turn signal and then afterwards with the new V3 Tritons for comparison
#4113
They were designed a few years ago, and there are more efficient LEDs on the market now. Quality bulbs using those LEDs can easily exceed the total light output of the Triton.
Thanks,
Paul
Mik3G37S (09-23-2014)
#4115
There are brighter bulbs on the market than the Triton. Total measured output of the Triton (white) is only 260 lumens after reaching operating temperature. We bought a pair and ran full lab testing on it. I believe VLEDs numbers are "initial" brightness but that quickly goes down once the bulb heats up a bit.
Thanks,
Paul
Thanks,
Paul
#4116
Our XP80 bulbs are measured at a true output of 510 lumens after full warm-up. But even our HP11 bulbs operate at 310 lumens, brighter than the Triton. These are actual scientific test results, not guesses or estimates from a manufacturer. The Tritons are very solid bulbs, but as I said, newer LED technologies now exist. Thanks!
#4117
Mike I'm not sure of the name, I'll check later when I have time and see if I can upload a few pics of them as well. I bought them off the bay so take that for what its worth. Dont take this personal but with everything else so dam bright upfront on your car....I dont even see the point of having the need of high output swithcbacks???? I mean how often do you run your headlights with your iron man on and turns at the same time? that would just defeat the purpose.....
off que a little bit here but why did you choose the 1/2 iron man vs the full?
#4118
The reason why I went for the "1/2" dual iron man vs the full is because
1) not many people have that
2) I really like the evil look
3)To compliment the evil iron man look front and back (outdated picture with old Invidia exhaust)
EDIT: to clear things up I was just talking about amber LEDs not switchbacks that I'm getting, the reason why I asked about V3 Triton Amber LEDs/switchbacks is because they are the same thing, same kit and I was just interested in how easy the install is but all I'm getting installed is V3 Triton amber LEDs in place of my old switchbacks as my turn signals are no longer noticeable with iron mans
#4119
#4120
I just like all my lights bright and visible, I'm very **** about lights on my car, and want my turn signal to be noticeable when running my dual evil iron mans on.
#4121
Now after looking at this picture, and seeing that red little dot visible through the back window, I remembered John, that last time You,Kevin, Ahmed and I met up, you shut off my Valentine 1 radar detector off I guess, must have annoyed the hell out of you when you took my car for a drive down the road, poor guy didn't know how to mute it
#4122
#4123
I believe my actual thoughts in the moment were, "What the fck is all this ****?"
Choman (10-07-2014)
#4124
Okay, you got me there! any pictures more preferably videos of those XP80 bulbs in action vs V3s or any other LEDs for comparison? Also found the flasher replacement way of fixing hyperblinking pretty interesting, is that applicable on our cars? I like that but even if I opted out for the bulbs, I think it wouldn't make sense to get the flasher replacement since I already have resistors added to turn signal bulbs' circuits for my current ones
Unfortunately the flasher module is not replaceable on the G-cars, otherwise it would be the best solution. If you've already added resistors to your turn signals you are good to go
If you have any questions about our LEDs, feel free to give us a call: (314) 205-3033
Nick C.
#4125
Now that makes alot more sense to me and the diff light color should help each offset the other as well as compliment them. Pics once done pls and I actually dont mind the taillights like that. Def something diff and now your iron man def pulls the whole thing together.
We haven't put together a direct comparison video of our HP11 or XP80 vs. the Tritons, but we have measured them in-house to determine the true lumen outputs under normal operating conditions.
Nick C.
Nick C.
