Remote starter installed!
#46
Ok thanks! Did you get the smart start installed? i was wondering if it just plugs into the dball or if you have to connect extra wires for that part? I'm on the fence about just using the OEM remote or trying to add something else for longer range (just not sure how things hookup to the dball).
From what I've read, the DBALL has a data port on it that nothing connects to (except the XKLoader during the flashing process). I believe Smart Start connects to this data port.
91ZCpe (01-23-2014)
#50
a DIY would be awesome!! I'm looking around now to source some of these parts I'm just curious about the wires that were not directly plug and play. Where exactly is our bcm located? Also what do you put on the wire ends to insert them into the blank spots on the bcm?
#51
The T-Harness comes with wires that have a pin to insert in the blank spots on the BCM plug. What I did was splice in ~4' of wire to each lead that travels to the BCM. That way the BCM pins remain on the end of each lead and can be inserted into the BCM. I also extended the PTS button wire as well. The wire they provided just wasn't long enough for my liking. When I extend wire, I solder in, heat shrink and then cable wrapped everything with OEM cable wrap. Looks a lot better than having these 3 wires just floating to one side of the vehicle IMO.
#52
Edit: called kartunes and no harnesses in stock. Have them on order but no eta. And they just had the dball2 in stock there for $120.
So I can buy either of these:
Can't find the harness online anywhere.
#53
The BCM is on the passenger side of the vehicle. If you are sitting in the passenger seat and take your right foot and move it all the way to the right of the vehicle on the footwell, the BCM resides right behind that plastic panel.
http://a248.e.akamai.net/pix.crutchf...THNISS3_DL.PDF
it shows the t harness and then page 7 lists the wire connections - was it just the 3 wires that go to the bcd (colored green on page 7 #15,#37,#39)? and then just the PTS wire #4? and the rest is plug/play to the harness? I guess it would make more sense if i had all of the parts already - just trying to make sure i have all the info i need ahead of pulling my dash apart. Thanks again!
#55
Toolfetch reviews | Customer reviews of Toolfetch | www.toolfetch.com yeah no thanks
EDIT: Best Buy appears to be an xpresskit dealer so I would try contacting them to see if they have or can get one. I'm going to call sometime next week
#56
Awesome. I'll run up there soon and grab one. I'll start looking for the dball as well.
Amazon.com: Directed Electronics Inc. DBALL2 with Dual HS CAN Channels: Electronics
Amazon.com: Xpres DBALL Kit Databus all Interface Module: Electronics
Thanks for all the info! So i found the pdf for the dball/t harness install:
Be patient and take your time with everything - do not rush it. And when you have tested all your connections and your module is programmed correctly, tie everything up nice and neat out of the way.
XpressKit.com - Where to buy will tell you where Xpresskit products can be purchased around your location.
#57
There are only a few places that sell the harnesses online. Keep in mind that the first link you provided is for a DBALL2 and that will use a different harness than the DBALL. You've got it dead on. You will need to extend the wires all going to the BCM as I have stated previously. I added ~4-5' on there just to be safe and have slack to tuck the wires in a safe, neat place. Be patient and take your time with everything - do not rush it. And when you have tested all your connections and your module is programmed correctly, tie everything up nice and neat out of the way. My local Best Buy quoted me something like $90+shipping for the harness. XpressKit.com - Where to buy will tell you where Xpresskit products can be purchased around your location.
#59
Does your place carry both cables? For some reason i am finding the Dball2 unit is about $10 cheaper than any of the regular Dball units, but i can't find the THNISS3C cable anywhere.
#60
I spoke to someone in the car audio department who then asked a tech. I'm located in Chester Springs, Pennsylvania (Philly). If you could actually get one, I'd throw in an extra 20 if you could extend it like you did to yours.
