Remote starter installed!
Old 11-22-2013, 10:19 AM
Snaoum
Snaoum's Avatar
No it will not work for manual. When using JUST the EVO ALL and setting option 15 (remote start) and not using an external remote starter module, it is only going to work for automatics.
IT will work for manual if you use it as only a bypass and wiring a separate remote starter. When turning option 15 on, certain outputs from the EVO ALL change and you wont have the necessary outputs to do anything with the clutch or gear.
You need to look into guide 8441, that is the one for stand alone remote starter.
Old 11-22-2013, 10:30 AM
inspector94
inspector94's Avatar
Ahh, ic, now that diagram makes more sense xD
Old 11-22-2013, 12:20 PM
botlfed98
botlfed98's Avatar
they offer a plug n play kit for my Jeep Grand Cherokee, I might start off with that kit first and see how it works.
Old 11-22-2013, 12:36 PM
dkmesa350z
dkmesa350z's Avatar
amazed by the laziness of some forum members. and since when is demanding a DIY versus asking politely for detailed install pictures, etc. cool? haha
this sounds like a relatively straight add-on. might be neat to try. i'll see if there is a bypass for the clutch requirement for 6mt owners...surely there is.
Old 11-22-2013, 01:14 PM
Snaoum
Snaoum's Avatar
If you want plug and play, look into the Xpress DB-ALL2.
NeverEnough007 (11-28-2013)
Old 11-22-2013, 11:33 PM
connoisseurr
connoisseurr's Avatar
Will the DB-ALL2 allow for the same remote start feature through the factory key fob? I haven't been able to find this information.
Old 11-24-2013, 01:11 AM
Snaoum
Snaoum's Avatar
Yes it will do that
Old 11-25-2013, 10:07 AM
connoisseurr
Would you recommend the DB-ALL2 over the EVO ALL? I seem to find more vaulable information regarding the EVO ALL, compared to little information regarding the DB-ALL2. Does anyone have any information regarding which to recommend?
Old 11-25-2013, 10:29 AM
Snaoum
Snaoum's Avatar
Yes the documentation on EVO ALL is better. DB-ALL2 is a great product as well, I have not used it for my install however I hear great things about it and if you purchase the plug and play harness it is a simple install. I think it will be just 1 wire to the BCM.
You can contact 'Broadfield' on here, he mentioned he does it for a living and does nissans/infiniti's using DB-ALL2
connoisseurr (11-25-2013)
Old 11-25-2013, 11:11 AM
connoisseurr
I'll reach out to him because I'm curious if it's worth it to go with the DB-ALL2 over the EVO ALL. I ordered one on Friday and it's already at my door
Old 11-25-2013, 11:55 AM
Snaoum
Snaoum's Avatar
Yes definitely contact him and see. I've done many installs, I enjoy it so the 10 or so wires I connected was simple and fun for me.
Old 11-25-2013, 11:57 AM
connoisseurr
Seemed like you had to hook up a lot more than 10 wires haha. I may just keep it. I do need to order (or rent) the flash updater tool. I will need that to enable the remote start feature, yes?
Old 11-25-2013, 12:27 PM
Snaoum
Snaoum's Avatar
Correct.
Old 11-25-2013, 08:58 PM
  #29
connoisseurr
I feel like it will take him a century to get back to me because he only has 1 post on here
Old 11-26-2013, 04:39 PM
  #30
91ZCpe
91ZCpe's Avatar
I'm interested in the EVO-all as well. I see that you're in NOVA; do you know how to install this? If so, maybe I can buy the flash tool and you could help install this for me and you can use the flash tool for your car.
Let me know..
Quick Reply: Remote starter installed!
