Poor man's G37 sedan mod page!
#106
Are they $40!!??!. I totally forgot how much i spend on them. Anyway, They were very poor quality. The metal was very thin and cheap finish. I put them back in the package and have never seen them again.
teonguyen (09-11-2014)
jsheets (09-15-2014)
#109
$35.99 hide-away plate
I didn't want it under the lip because NY roads are horrible, and didn't want to risk it getting ripped off. So I cut into the lower grille and mounted it there. Will have pics up later on.
#110
Diode Dynamics makes a nice acrylic panel. Went with the aluminum look myself. $12
If you have this version, its only $8
And some cheap & easy underhood bling, $12
Diode Dynamics (09-15-2014)
#112
Robot Check
Robot Check
tks
#114
flipmode007 (09-23-2014)
#116
I figured this might be a good thread to ask this question. Does anyone know where I could find a replica OEM-style sport lip for the G37 sedan (2012)? Replica non-sport lips are pretty common, but I don't think I've found a replica of the OEM sport lip for the sport sedan yet. It would be great to find something that looks identical without having to spend $350 - $400.
#117
#118
#120
[QUOTE=Rochester;3624879]$10 in primer and paint, and you can customize your engine cover. Here's mine:
dDid you just tape off the areas you didn't want black or yellow? or use a stencil? Anytime I try plasti dipping, I tend to get a lot of "pull" when I don't get an area completely taped! Also this is not plasti dip, but real paint correct?
