370z springs on X (Swift alternative?)
Finally got around to getting some photos - anyone looking for a drop a tit more subtle than swifts and a heck alot cheaper, this may be for you. Mind you this was done on a 35x, but I presume you'd get similar results on a 37x.
Front - 370Z oem front springs, ~1" drop
Rear - G35S oem rear springs, ~.50" drop
Coming from a g37s coupe, the handling still isn't quite as sharp, but it is a night and day improvement over the oem X setup.
In terms of height, prokit < swift < 370z < g35s < g35x
I was aiming for something in between, which the 370z fronts did. Unfortunately the 370z rears did not provide the same level of drop.
So given the drop in height and rise in spring rate, the Nismo springs would be a good fit up front. Not sure about the drop in the rear though. I'm thinking the S Spring rate might be a bit light in the rear. (for balance)
JohnsG37x
09-20-2015 09:24 PM
chris_s
09-08-2015 03:37 PM
