Lowering Springs Info For Sedans
Old 08-30-2012, 03:01 PM
ashmostro
ashmostro's Avatar
More likely you felt the difference between the tire profiles- 18" vs 19"
Old 08-30-2012, 03:44 PM
Paneraiguy
Paneraiguy's Avatar
What are peoples ground clearance numbers after dropping thier ride (clearance from the lowest point under the car to the ground)? I think that is a useful metric. Fender to ground is useful but more of a cosmetic metric. Ground clearance is a better reference point so guys can tell if they are going to be scrapping the hell out the car or if they will only have occasional issues.
Old 08-30-2012, 04:06 PM
rks
rks's Avatar
I have the Ark exhaust so I tend to scrape it more so than the front. I was actually too low on my KWs and raised it just to get up my driveway almost sideways.
Old 02-18-2016, 04:20 PM
Alexis Barragan
Alexis Barragan's Avatar
What is the drop on this car and which brand is being used?
Originally Posted by King_Stee
Eibach:RWD
Old 02-18-2016, 06:09 PM
Received 4,940 Likes on 4,174 Posts
Welcome to the site Alexis!
On top of that first pic it lists Eibach RWD, so it's an Eibach spring drop for RWD sedan, it's about 1.5" drop give or take a 1/4".
Old 02-18-2016, 08:19 PM
salmonslayer
salmonslayer's Avatar
Wonder if that drop needed camber kit? Looks perfectly lowered.
Old 02-18-2016, 08:27 PM
Should have one for the back, front should get by ok without,
Old 02-19-2016, 12:19 AM
MaQG37
MaQG37's Avatar
On that spring, my camber specs were -2.3 out back without adjustment.
Old 10-22-2016, 11:52 AM
Banshee
Banshee's Avatar
Is this list still accurate? Also, people should post their shock setup as well.
Old 10-23-2016, 01:36 PM
bluedevils95
bluedevils95's Avatar
I am sure this is still accurate.
Old 10-24-2016, 02:10 PM
xpcgamer
xpcgamer's Avatar
Nah...Last year I bought the H&R springs going by the list on the 1st page and every one came back and told that they would drop my car more than that easy. So take that list with a grain of salt.
Old 10-20-2020, 01:00 PM
Blake A. Durgin
Blake A. Durgin's Avatar
My B&G S2s drop the same as S techs to add to your data base ($200-240)
Also H&Rs drop about the same, much lower than what's listed.
Here's my drop
yeah, I was about to say the same thing. H&R spring drop about 1.5-2.0
G's
11-05-2023 12:01 PM
m3clubracer
08-19-2015 03:48 PM
Dillybar12
08-17-2015 04:52 PM
MeatySock
08-14-2015 08:25 AM
Rubyq60
08-03-2015 10:36 PM
Quick Reply: Lowering Springs Info For Sedans
