Top Speed exhaust for the Sedan?
Old 09-15-2016, 09:48 AM
  #241
Ricio1991
Ricio1991's Avatar
Thinking about getting the top speed y back, m2 performance y pipe and fast intentions rhfc any thoughts? Found a Good deal 950 for all included used for about 5k miles. What do y'all think?
Old 09-15-2016, 10:04 AM
  #242
Ricio1991
Ricio1991's Avatar
Also should I wait to install these mods when I'm ready for a tune I don't want to damage anything will I be running too rich with Stillen gen 3, fi rhfcs, and y pipe and top speed y back? Thoughts?
Old 09-15-2016, 11:12 AM
  #243
dimsler
dimsler's Avatar
The stock tune does a great job compensating for your mod selection. Only issue I'd see with that setup is it might drone and be a tad too raspy with the HFCs.
Old 09-15-2016, 11:28 AM
  #244
Ricio1991
Ricio1991's Avatar
The resonated fast intentions high flow cats should not provide that much rasp which I heard very good things about but I'm not too worried since they are resonated. Thanks for the input I will then install them and tune later. Pretty excited for this set up
Old 09-15-2016, 11:37 AM
  #245
the93owner
the93owner's Avatar
I don't know the specs off the top of my head but you want to make sure the diameters of each component is the same all across, otherwise that could cause even more rasp or unwanted noise. You should be fine without a tune for now but you would want one eventually to help with performance and to run at peak efficiency.
Old 09-15-2016, 11:42 AM
  #246
Ricio1991
Ricio1991's Avatar
In asking the owner but he stated that he has no issues and it's not too loud. Let me see if I can do some research
Old 02-25-2017, 10:39 PM
  #247
Surge Shamray
Surge Shamray's Avatar
I read all 17 pages of this thread and it seems like the earlier posts said it sounds really good and has awesome fit and finish and then the later posts mentioned issues with fit and finish....that being said is buying a top speed system still a good idea for someone who wants better feedback from the throttle without spending over 1K or what would you guy recommend
I was also interested in some long(er) term reviews of this set up.
thank you
Bear Slate (02-26-2017)
Old 02-27-2017, 11:37 AM
  #248
Brochenko
Brochenko's Avatar
I've had the Top Speed Y Back on my G37x sedan for almost a year (got it March 2016). I painted the mufflers with Rustoleum high heat black paint to protect against rust. It has recently started to peel off and rust in some areas, mostly on the tips. I'll probably repaint it once the weather gets warmer.
The install wasn't too bad. It was slightly crooked, but after spending a little time adjusting it I got both tips pretty aligned. The other issue is the driver side pipe: it's pretty close to the rear diff. So on cold starts it seems to be hitting off of it and rattle, it goes away once warmed up. I have no drone that I have noticed.
Almost 1 year later, there seems to be a leak. I'm guessing because of the cheap gaskets it came with it. I'll probably be replacing that in addition to adding a resonated x pipe to replace the y pipe. Overall I don't have too many complaints. Other then the steel used (seems that many people noticed it rusts quite quickly) and some minor fitment issues. I'd say it's a pretty good purchase. Only thing I'd do different is get better gaskets before installing.
Old 02-27-2017, 09:11 PM
  #249
Received 4,940 Likes on 4,174 Posts
Mine's 5 years old now and still sounding and looking great. I had to get new tips because the bottom of mine were scraped all to hell from our steep driveway and my previously lower drop. If the quality is similar now as it was back then I assume you'll get good value w/ that purchase. If you live where there's a lot of road salts and brutal winters you might want to spend more but ???
Old 03-04-2017, 07:33 PM
  #250
Surge Shamray
Looks decent esp given the price but it doesn't look like the sedan y back is in stock anywhere
Old 03-04-2017, 07:41 PM
  #251
Might look at the J2, a few guys have them around here and they seem to be a pretty decent setup for the price, and if you black out the exhaust cans it will look even better. These are a true catback rather than the Y-back of the Topseed set, so it's not a bad way to go.
J2 DUAL MUFFLER TIP STAINLESS CATBACK EXHAUST FOR 09-13 INFINITI G37 V36 4DR VQ | eBay
Here's a DIY on the painting of the cans
https://www.myg37.com/forums/d-i-y-i...-blackout.html
Old 03-04-2017, 08:17 PM
  #252
Surge Shamray
AWD so my options are kind of limited compared to RWD
I basically copied this dudes set up, tanabe axle back, megan y pipe and got some vibrant 12 inch resonators...still waiting for all the parts to come in.
A lot of ppl on here seem to not like the quality of the stillen catback but really like the tanabe but say it's not loud enough (which the 2 mods above should fix I think)
still waiting on all the parts
Old 03-04-2017, 11:20 PM
  #253
Should get a decent result going that route, if you have any drastic differences in pipe diameter it will introduce rasp so try to use reducing pipe sections if that's the case.
Old 03-05-2017, 07:32 AM
  #254
Surge Shamray
I think its 2.25 or 2.5 for all the components, I will post a video when I get it installed
Old 03-05-2017, 12:34 PM
  #255
Ricio1991
Ricio1991's Avatar
I like how it looks especially after there cleaned
Quick Reply: Top Speed exhaust for the Sedan?
