Notices
Switchbacks on 2010 sedan(Video)
Old 04-28-2011, 09:38 PM
maxfinity
maxfinity's Avatar
Rushed Video made with my Cell Phone. Sorry about the Quality.
<iframe width="425" height="349" src="https://www.youtube.com/embed/4afxT8NkdSs" frameborder="0" allowfullscreen></iframe>
Old 04-28-2011, 10:44 PM
eksigned
eksigned's Avatar
Your navi screen split with the mpg info's different than mine!...Hm
Anyways, thanks for the video man! I've always pondered getting switchbacks, but got annoyed with the whole resistor thing. How'd you get the fast blinking to spot? Resistors right? Install DIY?
Old 04-28-2011, 10:45 PM
eksigned
eksigned's Avatar
Old 04-28-2011, 10:50 PM
eksigned
eksigned's Avatar
ah...now i get your forum id - maxima + infiniti lol
Old 04-29-2011, 02:20 AM
maxfinity
maxfinity's Avatar
I changed the rear signals to LED bulbs as well so I can use the 3ohm resistors instead of the 6ohm. I placed the 3ohm resistor in the rear since its alot more space to work with making it much easier to connect the resistor. I 3ohm resistor on Both signals in the rear stops the Hyper Flash in the front and rear. I chose this method because its a real PITA trying to connect the resistors to the front wires.
Also... Whats the difference with the Navi Screen? I thought hey were all the same.
LOL... Yeah I couldn't think of any other user ID. I didnt realize "finity" was spelled incorrectly until it was too late.
Old 04-29-2011, 03:12 AM
MyocyteX
MyocyteX's Avatar
Props. This is so sick. I have never hear the term "switchback" but I get it. I want this mod. Its just bad *** and fun, I would be clicking the switchbacks alllll daaaay!
thanks for the vid!
Old 04-29-2011, 03:47 AM
Ibanez540r
Ibanez540r's Avatar
The NAV screen can be adjusted to be split with whatever you want on each side, or just one thing, including just the NAV map on the entire screen.
Hit settings> navigation > map settings?, I can't remeber without doing it, but it gives you quit a few options, all the way to the 3d angle of birds eye. Check out your manual, or go through all those settings, you'll find it.
Old 04-29-2011, 08:34 AM
Djfarhan
Djfarhan's Avatar
the bubs? ;-P
Old 04-29-2011, 10:10 AM
mswistak14
mswistak14's Avatar
I just did this similar setup and for some reason I couldn't get my passenger side to stop the hyper flash. I installed the resistor across the front driver side and it prevented the flash, but for some reason I couldnt get the resistor on the passenger side to stop it. So now I just have hyperflash. Any tips? I do not have any rear LED tail lights.
Old 04-29-2011, 05:12 PM
maxfinity
maxfinity's Avatar
You just have to make sure the metal in the splice is touching the metal in the wire. Take some pliers and apply a little more pressure to get a better connection. I had the exact same issue when I tried to connect the resistors to the front.
Old 04-29-2011, 06:17 PM
roots4x
roots4x's Avatar
You only need one set of resistors per side. The 3 ohm should be for when you have two LEDs and the 6 ohm should be for when you have one LED pe side. 3 ohm resistors draw more current than a 6ohm so it (3ohm) simulates having two bulbs.
Old 02-02-2012, 02:41 AM
MistAminER112
MistAminER112's Avatar
Thanks for all the useful help! This thread has really helped out a ton!
Old 02-04-2012, 12:19 AM
ak47
ak47's Avatar
damm ur mpg is great. i am getting 13 mpg
Old 02-04-2012, 01:13 AM
Rickyay
Rickyay's Avatar
what bulbs are u using for ur fogs?
Old 02-04-2012, 07:07 PM
maxfinity
maxfinity's Avatar
The fogs are cheap ebay bulbs. I'll be upgrading them soon. Trying to find a reputable company with good long lasting bulbs.
Quick Reply: Switchbacks on 2010 sedan(Video)
