Notices
Clicking noise when turning the steering wheel
Old 03-06-2011, 04:40 PM
bythabay
bythabay's Avatar
Hello all,
2011 G37 Sedan 6mt. I have been hearing a strange noise and I am trying to figure out if it is normal or if something is wrong with my G.
Steps to reproduce:
Park vehicle on a flat level surface with wheels facing straight ahead.
Turn off engine
Engage parking brake.
Set gear shift into park or put 6MT into gear.
Tap start button once, to allow the steering wheel free movement without lockup.
Slowly turn steering wheel 1 or 2 degrees to the left, then repeat by turning to the right.
Do this a few times, pay attention to a clicking type sound that is heard from somewhere near where the steering rack connects to the steering column.
Does anyone hear any clicking sounds or other unusual noises? I've looked at a few other cars, and in the case of the G the noise seems a bit excessive and almost binding.
Old 03-07-2011, 01:33 PM
fastlane45
fastlane45's Avatar
Had this happen to me too.. dealer replaced spiral cable and the noise stopped
Old 03-07-2011, 01:55 PM
bythabay
bythabay's Avatar
Good thing I posted.... would you mind scanning in your work order so that I can reference it when I go to the dealership?
Old 03-07-2011, 02:30 PM
erdog
erdog's Avatar
I need to listen to your car. I can barely hear it. Its so subtle. I can only barely hear it when the car is not running.
Old 03-07-2011, 02:33 PM
bythabay
bythabay's Avatar
yeah, you need to check out my exhaust note too...
Old 03-07-2011, 03:31 PM
Okita240
Okita240's Avatar
I have this same exact problem. Dealer replaced all parts related to steering but it did not resolve the issue. Then they were able to reproduce it on another new 6MT sedan on the lot. At this point, they claimed that it is by design. I hope Infiniti corporate creates a TSB for this.
Old 03-07-2011, 04:04 PM
bythabay
bythabay's Avatar
well at least the noise is not there while driving
Old 03-07-2011, 11:37 PM
fastlane45
fastlane45's Avatar
will a picture do? i dont have a scanner at the moment but here..
*not sure if that will be big enough for you to print i can email you the full picture if youd like
Attached Thumbnails Clicking noise when turning the steering wheel-cimg0639.jpg
Old 03-08-2011, 02:30 AM
bythabay
bythabay's Avatar
thanks, that'll do
Old 03-28-2011, 04:39 PM
Okita240
Okita240's Avatar
Hey OP, did you ever get this issue resolved?
Old 03-28-2011, 05:13 PM
bythabay
bythabay's Avatar
No, I just decided it was probably normal.
Old 03-28-2011, 06:07 PM
Maxpilot
Maxpilot's Avatar
It's not normal. On my 08 it was what is called the "clock spring". It was replaced on warranty.
Old 03-29-2011, 11:06 PM
Okita240
Okita240's Avatar
I wonder if any other 2011 G37S 6MT Sedan owners are having this issue. It's just not right that the car makes this sound.
Old 03-30-2011, 07:07 PM
JENG37S
JENG37S's Avatar
Mine is a 2011 also. Just this morning going in to work with everything turned off(radio etc..)and going slow I heard that same noise. Have an appointment next week to have it looked at. I'm going to make a note of that work order that was posted.
Funny this thread should pop up just when it happened!
Old 04-08-2011, 07:10 PM
JENG37S
JENG37S's Avatar
Well they lust called me to say the noise is NORMAL?
I don't think so....going to try another dealer.
Quick Reply: Clicking noise when turning the steering wheel
