Notices
auto up on window not working
Old 11-14-2015, 07:21 PM
Murkr
Murkr's Avatar
just installed a R2C intake and had to do this because i disconnected my battery.
Great intake, i get faster trottle response " less lagg" and it sounds a lot better.
thanks for this tip!
Old 11-14-2015, 09:04 PM
qmantran
qmantran's Avatar
Did it occur to you that the improved throttle response you're feeling is most likely due to the fact that you had the battery disconnected which resets the ECU?
It's widely known that resetting your ecu will increase throttle response
Old 11-16-2015, 07:39 PM
4DRZ
4DRZ's Avatar
...slowly sneaks outside to disconnect his battery
This same issue of resetting the auto windows works on a lot of other brands of cars too. You may also have to reset your sunroof too. If you have an auto roof it will probably just open an inch at a time. Just open it all the way and close it and it will reset
Old 08-27-2016, 02:00 PM
Antxo713
Antxo713's Avatar
Originally Posted by EnviedG35
Roll the window down, then roll the window all the way up while holding the button for 5 seconds after the window is fully up. This is will set the auto up back to normal
Thank you!!
Old 11-06-2016, 04:06 AM
Banshee
Banshee's Avatar
Originally Posted by Antxo713
Thank you!!
Bumping this. What if this particular G37S forgets how to auto roll up windows even though the battery has NOT been disconnected? Just did a small 120 mile round trip with AC on and a bit of cruise control. Any idea why this may have happened? I got frustrated and feel bad that I doubted the vehicle. Fixed it with the 5 second thing. Still curious.
Old 06-09-2017, 12:30 AM
Kpmikey808
Kpmikey808's Avatar
930pm vegas June 8/17
Just happened to me driving to the restaurant- weird
Old 06-09-2017, 10:35 AM
Nico-derm
Nico-derm's Avatar
Mine too,
Will try this fix when I get home tho!
Old 06-09-2017, 02:36 PM
Kpmikey808
Kpmikey808's Avatar
I worked
Originally Posted by Nico-derm
Mine too,
It worked the first time & I was stoked
Old 06-10-2017, 06:41 PM
Kaykoose
Kaykoose's Avatar
My issue is different. Rolling down all 4 windows by holding down the unlock button on the key fob has suddenly stopped working. Thought resetting the windows would help but no luck. Any ideas? Perhaps whatever controlling it has failed and I should give up on it... I did use it quite a bit though. Very cool feature.
Old 06-11-2017, 12:39 AM
Kpmikey808
Kpmikey808's Avatar
Should search in forums
Theres gotta be a thread for that
Old 06-12-2017, 09:16 AM
Nico-derm
Nico-derm's Avatar
worked like a charm
Kpmikey808 (06-12-2017)
Old 06-12-2017, 05:55 PM
4DRZ
4DRZ's Avatar
That is definitely a feature you will lose if you need to reset your windows. After you reset the windows they now work- auto up and down from inside ok? I only ask because I had to reset mine to get the roll down feature with the remote to work again.
Oddly enough, that feature does not work all the time. The car will unlock, but sometimes I have to unlock and hold the unlock button down a few times to get the windows to roll down. Cool feature in the summer, especially with the leather seats (for now)- when it works anyway.
Old 04-21-2019, 05:00 PM
deepblue3
deepblue3's Avatar
My car was doing the same and this totally did the trick!
Old 03-07-2021, 01:19 PM
  #29
JakeC
JakeC's Avatar
I know this is from a while ago but you are the BEST!!! Thank you!!!!
fercho89
08-09-2018 10:49 AM
bryanscott
General Tech Questions
06-07-2018 05:36 AM
Pieman
05-20-2014 04:25 PM
CrazyBulgarian
02-20-2013 01:53 AM
SlateBlue G
10-16-2012 06:56 PM
Quick Reply: auto up on window not working
