G37x Rough Brake Feel
Old 10-11-2009, 06:41 PM
BluSlate37x
BluSlate37x's Avatar
Has anyone noticed a rough or 'scratchy' feel from the brake pedal when braking? It is somewhat like if the rotors were scratched or slightly grooved. Not as in warped rotors but kind of a similar feel like if you were riding over a rough cement road vs a new blacktop road (sorry, this is the best I can describe it). Of course, dealer said all is working normally
Old 10-12-2009, 08:03 AM
gugarci
gugarci's Avatar
I think what you are experience is road surface feel through the brake pedal. I had this on my 08 and my 09. I've also experience this in the loaners G's I've used. On smooth road is not as bad but is there.
Old 10-12-2009, 08:28 AM
wireboltman
wireboltman's Avatar
No problems here at all-
Old 10-12-2009, 09:28 AM
rehtea
rehtea's Avatar
Yes, I experienced the exact same thing you described, but only once or twice. I believe it might be the ABS kicking in, since the brakes on the G37 seem very grippy (a good thing). I had to adjust to feathering the brake pedal instead of stomping on it.
Old 10-12-2009, 10:06 AM
da mayor
da mayor's Avatar
maybe it's b/c of the rust on the rotors?
Old 10-12-2009, 10:55 AM
JonfromCB
JonfromCB's Avatar
BlueSlate' Here's a little test you could do just for your own
edification. Find a nice smooth secluded stretch of road where
you can do a couple of hard and harder stops from say
60MPH, where you can feel safe, and not have to focus
on other cars. See if you can make a stop or two
so you can actually feel the difference between a non-ABS
stop and an ABS engaged stop. My guess is that what
you are noticiing is either road feedback through the pedal
or you are actually enguaging the ABS as previously
suggested by others. I have noticed that the ABS
on my G37X seems to enguage much more easily than
any of my previous cars. Good luck
Old 07-22-2014, 09:23 PM
g37mke
g37mke's Avatar
was wondering the same thing
I just bought a 2011 g37x S and was wondering the same thing. Relieved to hear these responses. I noticed that it wasn't consistent but thought it may be from heat.
Old 07-24-2014, 09:57 PM
00Max00
00Max00's Avatar
I wondered the same when I bought the car new, the brakes were smooth as glass after a few thousands miles. You probably need to break the pads in if they were just replaced.
Old 07-30-2014, 01:21 PM
rk_2012G37X
rk_2012G37X's Avatar
Just purchased '12 G37X with 21k miles. It sat for a bit on the dealer lot so it had some rust on the brakes. I'm happy to read this thread because I thought something was wrong on my ride home from dealer. There is definitely a lot of feedback through the pedal. Seems to have gotten a little better as rust wore off.
Old 09-17-2014, 10:13 PM
TaijiG
TaijiG's Avatar
I recently bought a 2011 G37 certified pre-owned with 26000 miles, I have the same issue,I never owned a car with brake feel like that> brought it to the dealer, they first changed the front rotors (because there was something in car history with front brakes), then I came back and they changed the back rotors, I paid for new pads. Still feel that road feel and rough rotor feel. Is that normal for all the G's or just some,or maybe it will work itself in. The loaner Q50 while car being repaired felt nothing like that.
Old 09-17-2014, 11:34 PM
AUR11
AUR11's Avatar
I hated the x brakes. I upgraded to Akebono and can say it made a huge difference.
Old 10-06-2014, 09:28 AM
gbest03
gbest03's Avatar
I had that roughness, replaced the rear pads/rotors with OEM, problem went away until the front started doing it, replace those, and now the rear is acting up again.
Garbage parts.
Old 10-07-2014, 01:40 PM
kluthage421
kluthage421's Avatar
Most OEM rotors will warp around 20-30k. Infiniti will turn them free of charge due to a TSB. Best bet is to get some aftermarket rotors and pads. I have the Akebono Performance OEM and I love them. The like to warm up a bit, but don't have the annoying quick bite like the stock pads. Once warm they are progressive and smooth. "Someone I know" has had to do some 120-50 hard brakes unexpectedly and they exude confidence.
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
derekjl
10-02-2015 05:05 PM
Mattlorentzoe
08-21-2015 03:54 PM
drewfinity
08-20-2015 08:17 PM
reigle9
08-06-2015 02:45 PM
Quick Reply: G37x Rough Brake Feel
