Clutch Slave cylinder replacement
I've replaced the master about 4 times. 2 on mines and 2 on my buddies. First time took me over 6 hours, after that took only 2 hours. Biggest PITA is getting the master out. Clearance is very tight and getting the brake booster out of the way gives you more clearance. Also the last bolt in the dash by steering is a pain.
Thanks for all the replies! I just picked up my 08 g37s last week and I'm already having to take it in to get fixed. I was quoted several prices with several different replacement parts, but no one offered or is even considering a stronger aftermarket CSC.
Csc
I did the stronger aftermarket slave cylinder on my 09 g37s. I paid $300 for the part and had someone install it for $500 (yes, it is in the transmission). 6 months later had the same issue, but this time it somehow leaked hydraulic fluid into the clutch and ruined it. I then discovered Zspeed CMAK kit. Here is the link http://www.zspeedperformance.com/. I ended up paying about $1,300 for a stage 1 clutch and the clutch movement alteration kit. The labor was still $500. The system works great, and if you by any chance ever need to replace the slave cylinder again it can be done at home without removing the transmission. I would suggest looking into this.
Johnieg37s08 (12-23-2020)
I did the stronger aftermarket slave cylinder on my 09 g37s. I paid $300 for the part and had someone install it for $500 (yes, it is in the transmission). 6 months later had the same issue, but this time it somehow leaked hydraulic fluid into the clutch and ruined it. I then discovered Zspeed CMAK kit. Here is the link ZSpeed Performance Nissan Infiniti Specialist 240SX 300ZX 350Z G35 G37 370Z. I ended up paying about $1,300 for a stage 1 clutch and the clutch movement alteration kit. The labor was still $500. The system works great, and if you by any chance ever need to replace the slave cylinder again it can be done at home without removing the transmission. I would suggest looking into this.
I bought the clutch, flywheel, and CMAK kit from zspeed online. The cmak kit is pretty easy to install. My mechanic only charged me $100 (an hour) to install it, and $500 for the install on the clutch and flywheel. Hopefully you won't need the clutch and flywheel, but trust me, I wouldn't waste any money on a "stronger" csc.
I forgot to mention the clutch is made by zspeed. I chose it because I after spending that kind of money I wanted some a little more heavy duty, and I live in Houston where there is a lot of traffic, and I didn't want something to stiff. I'm not sure if it's the clutch/flywheel, the CMAK kit, or the combination of both, but there is definitely an improvement on the performance. I love the setup I have right now.
