Remove front seat need to disconnect battery??
With all of these airbag issues I would remove the negative post when removing the seat. I have a 2003 G35 and the seat needs to come out. I'm unhooking the battery..
The Steering Wheel Guy
From my multiple experiences removing and installing seats.
1. Disconnect the negative terminal.
2. Remove seat.
3. Install seat.
4. Reconnect the negative terminal.
No recoding or lights illuminated. If you start the car with anything disconnected, an error is likely that would require resets or recoding.
I am assuming when he says "paint", he means that he is going to color swap his leather. It is actually like painting the seats (with a special type of "paint").
2. Remove seat.
3. Install seat.
Just say no!!!!!
My comment was in context of the SRS system possibly recognizing lack of an airbag even though the system is off. I suppose if the car remains off then the safety systems are not energized anyway.
Come to think of it, having the doors open should be enough to drain anything remaining.
