How to stop hyper-blinking?
Months ago I installed Diode Dynamic's DIY (Now they sell a specific plug-and-play kit for the G37 ) Tail-As-Turn modules to bypass the incandescent blinkers and make the LED rings my turn signal. Now since the incandescent bulb wire was cut, the wattage is lower than normal and the car thinks the bulb is burnt out.
To fix it, I also purchased DD's resistor kit. But, I haven't been able to fix the hyper-blinking. Maybe I'm wiring the resistors incorrectly?
In the first picture, I wired the resistor to the stock blinker wire that was cut and then other side to ground. Second picture, wired resistor to the LED rings before the module and then to ground-- to no avail.
I emailed DD and one of their reps said to, "install the resistor on the turn signal wire that you cut, before the module, and attach the other end to the ground."
Any ideas?
(disregard green tape, not sure why I put that over the crimp connectors)
[/URL]
Any ideas?
[/URL]
My guess is the resisters aren't wired in properly.
Morgan, are you still having the problem?
If you are, you should move the resistor tap (the one you relocated between pic 1 and pic 2) to the solid green wire next to the white (OEM block) plug. That is your turn signal. I was having a similar issue too.
You connected the resistor to the yellow / spliced into solid-green wire that is coming after the module going into the white OEM block pug??
The one circled here?
Thanks everyone, I will try what you suggested later this evening to see if I can finally defeat the hyper-blink troll.
parkern
10-05-2015 12:12 PM
FlyIce
09-29-2015 04:07 AM
mikysee
09-28-2015 11:18 AM
