what is transaxle fluid? Is it same as Automatic Transmission fluid on a G37x.
Hello friends!!
What is transaxle fluid? On a 2009 G37X sedan is it same as Automatic Transmission fluid?
My car has about 31.5K. I'm going to take my car in to the dealership for an oil change and some other warranty work( noise from steering wheel column). Dealer said he'll do differential fluid change and transaxle fluid change for $150. I initially thought he meant Automatic transmission fluid, but he said transaxle fluid is diffrent from ATF.
Questions:
If ATF and transaxle fluids are different, which is more important: ATF change or Transaxle fluid change?
If I'm getting differential fluid change now, can I get ATF and transfer case oil changed later? Or should all these fluids be changed at the sametime?
Questions:
Yes, for the G37x per the manual both the A/T and transfer case use a Nissan-specific ATF ("NISSAN Matic S ATF") - and also per the manual using anything different will void the warranty.
Also, FWIW, the G37 A/T is lifetime fill. The only benefit of changing it is for your dealer's bank account. The transfer case and differentials are lifetime fill as well if not following the "premium service" (which IMO exists to benefit your dealer).
I bought this car used. So, I thought I would get the fluids changed if the dealer is not charging big money.
I'd be wary of trying to equate the two as primarily I'm not sure what "transaxle fluid" is. Some vehicles use ATF in the transfer case. Some vehicles use gear oil.
From the 2009 G37 Owners manual selction 9-2:
Automatic Transmission Fluid: Genuine NISSAN Matic S ATF*3
Transfer Fluid: Genuine NISSAN Matic J ATF*8
Front Differential Gear Oil: Genuine NISSAN Differential Oil Hypoid Super GL-5 80W-90 or API GL-5 Viscosity SAE 80W-90*6
durability, and may damage the automatic transmission, which is not covered by the INFINITI new vehicle limited warranty.
*6: For hot climates, viscosity SAE 90 is suitable for ambient temperatures above 32°F (0°C).
*7: See an INFINITI dealer for service for synthetic oil.
Unless you are driving you car hard, replacement of those fluids at this point is a waste of $$$. Consult your recommended service guide for non-dealer influenced service intervals.
Brian
Rear Differential Gear Oil: Genuine NISSAN Differential Oil Synthetic 75W-90 or API GL-5 synthetic gear oil, Viscosity SAE 75W-90*7
*3:
Using automatic transmission fluid other than Genuine NISSAN Matic S ATF will cause deterioration in driveability and automatic transmission
*8:
Using transfer fluid other than Genuine NISSAN Matic J ATF will cause deterioration in driveability and transfer durability, and may damage the transfer, which is not covered by the INFINITI new vehicle limited warranty
Brian
Note the transfer fluid is Matic J.
Totally agree with the "lifetime fill" and following the factory service recommendations. That being said, as I approach 80k miles I'll probably change everything to be safe. The PO of my car left service receipts in the glove box and the dealer really did a number on him in terms of recommended services - brake fluid change at 30k??? LOL.
I'm confused. Can someone dumb this down for me. I have a 2009 G37xS, with 60,000 miles. What should I change with respect to transmission fluid, diff fluid, transaxle fluid. From posts above, it sounds like none are required (lifetime fill). I do drive it hard, so I'd like to hear what's required, and what's recommended. Thanks.
modme and gocougs - where are you guys getting the info on Matic S for the transfer case? I'm looking at a PDF of the manual for 2009 G37 sedan and coupe right now and it recommends Matic J for transfer fluid.
Are there different versions of the manual?
ZenZiglar - if you drive your car hard I would also recommend replacing all of the fluids at around 60k.
Brian
Brian
Brian
*3:
*8:
Brian
Thanks Brian for your response.
I drive my car hard and I bought this used. I dont know how this car was driven by the previous owner. Thought it would not be a bad idea to change front and rear differential and transfer case oil at this point. I"ll do or I might do the transmission and coolant flush at 45k or 60K
Actually, for the G37 brake fluid change is a mandatory 30k factory service - that's not the dealer making something up or pushing an optional/recommended service. Brake fluid loves to absorb water.
If modern cars were this sensitive to fluid changes (including oil) they wouldn't last half as long as they do. Modern cars, and in particular modern fluids, are engineered for very long if not essentially lifetime fill. Me I'm going to take full advantage of it and not have a worry that I am sacrificing reliability or performance.
