1st gear slipping?
Old 11-01-2012, 12:48 AM
TakmaN
TakmaN's Avatar
1st gear slipping?
I finally picked up my new to me 2008 G37s Coupe 6MT and love it! I am coming from a 2007 Honda Accord Coupe (AT) so this is leaps and bounds more fun to drive.
However, I noticed that sometimes when I'm starting from a stop in first gear, I get a minor but noticeable stuttering/vibrating/shuttering. It doesn't happen every time which is what is confusing me (but it does happen more often than not). It happens kind of randomly even after the car has been warmed up. I'm still wondering if it is me getting used to the clutch and catch point but it doesn't quite feel right (my Honda S2000 was easy to start off smoothly in 1st). 2nd through 6th are fine and dandy so I'm wondering if first gear is just a bit finnicky in this car. I took the car to a mechanic before I purchased it and he confirmed the clutch was fine. I don't believe the transmission fluid has been changed yet (32K miles on the car), could a flush help with this? Or is this a minor quirk with the 2008 6MT G37s and I need to learn how to drive it?
I'm debating going to a Carmax or somewhere similar to test drive another 6MT this weekend to compare. Otherwise the car is bomb.com!
Old 11-01-2012, 02:59 AM
JSolo
Just say no!!!!!
JSolo's Avatar
I get a bit of that too if I don't give it enough throttle soon enough when taking off. I think its just characteristic of this car. Other g37 6mt's I test drove had similar effects.
Old 11-01-2012, 03:56 AM
TakmaN
TakmaN's Avatar
Thanks Jsolo! After more research, it looks like this is just the way the clutch is. I found the thread on the clutch spring so hopefully that will help.
Old 11-01-2012, 06:42 AM
SwissCheeseHead
SwissCheeseHead's Avatar
Nothing short of a new clutch and fly wheel really helps. I got the assist spring from Jsolo and it helps the pedal feel by a ton, but I still get what you've described. Its just the way the car works.
Old 11-01-2012, 09:08 AM
john91
john91's Avatar
Does your slip button lights up on the dash? I'm thinking maybe its just traction kicks in... or you had it off?
Old 11-01-2012, 05:33 PM
SwissCheeseHead
This is different than the rear wheels slipping.
Old 11-01-2012, 06:14 PM
Ragincajun5220
Ragincajun5220's Avatar
I notice the same thing. Slipping feel when coming out of first. Odd, but makes me feel better that it's not just my car
Old 11-01-2012, 06:25 PM
Invalid
Invalid's Avatar
Same thing with my car, it's just the way the car operates. Usually happens when the engine is still running a little cold.
Old 11-01-2012, 06:49 PM
TakmaN
TakmaN's Avatar
Thanks for the replies all. I was playing around with the clutch on my way into work in traffic and I get the shudder with too much or too little throttle. Releasing the clutch really really slow seems to help but I can still get it to shudder this way as well when not matching the throttle up perfectly.
I can get a good start in 1st maybe 25% of the time. I feel like I'm learning to drive manual again.
Old 11-02-2012, 06:00 PM
cruzmisl
cruzmisl's Avatar
A good percentage of people that drive a 6mt in the G or Z will say this. Compared to other manufacturers, we have some work cut out for us.
Old 11-02-2012, 09:04 PM
TakmaN
TakmaN's Avatar
Indeed! Reverse works great however. It pulls smoothly from a stop but once I go back to first, I have to really think about my clutch/throttle balance. A minor quirk to owning an otherwise great car!
Old 11-03-2012, 07:31 PM
Ragincajun5220
True, but I think in gear shifting and especially downshifting is extremely easy in this car, especially compared to my old e90 m3
37
10-17-2020 11:12 AM
vamarris
12-09-2018 11:10 AM
r0cketm0nkey
General Tech Questions
17
11-23-2015 03:34 AM
inspector94
09-08-2015 12:57 PM
Quick Reply: 1st gear slipping?
